New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
07-19-2009, 10:16 PM
Been a busy weekend
Spent several hours yesterday installing my leveling kit. Went with the one from Zone off road. Price was right, cane with the adjustable track bar and was way cheaper than comarable set ups. Ride isnt too bad and raised the truck 3+ inches. I guess the stock springs were sagging more than I thought. Also got a grille insert I found on fleabay. Here again half the cost of comparable ones. Everything was looking so good up front that I splurged and updated the bug shield. Just needs some new eyeballs up there now. let me know what you think
__________________
Mark
Quote: A dog naps so much because they love so hard.
01 F350 4x4 CC LWB Lariat, 6637, Pete's cover, ISSPRO EV2 guages, CCV, MBRP 4" Turbo back exhaust, DP Tuner N/S, Stock, 60T, Decel, 80T, 80E, 120R...Thanks Clay, Riffraff AIH delete W/ boost, foil delete, billet grille, Zone offroad 2.5" level kit.
07-19-2009, 10:19 PM
Redneck Wrencher
Looking good Mark.
__________________
-Roland -
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
07-19-2009, 10:23 PM
Rather Be Floatin
Looks good!
__________________
Costa
2003, F-250, 7.3L, 2wd, Auto, 4 Door, Lariat, Short Box, DP-Tuner, Isspro Pyro, Boost, and Tranny Temp, 6637 with Petes cover, Fumoto, Bilsteins,
2" Leveling Kit, Hutch/Harpoon, Foil Delete Mod, Upgraded boots, CCV Mod, Ac Improvement Mod, Michelin LT285/75R/16 LTX AT2's
07-19-2009, 10:28 PM
I AM a sexy man!!!!
2001 Ford F-250
looks good... you got a link to that kit?
__________________
Nolan
2001*F250*Ext.Cab*LB*4x4*6spd
4"turbo back exhaust, 6637w/custom Pete cover, Gooseneck hitch, Cobra148GTL w/102" whip
PAA #64
07-19-2009, 10:36 PM
Here is the link I used. Called the guys before purchasing and was impressed by their customer service.
http://zoneoffroad.com/product?ki=145&gr=-1
__________________
Mark
07-19-2009, 10:37 PM
looks good Mark
__________________
Pete
2001 F250, Platinum Edition (1 of 2482,thanks Ed ), CC, SB, 4x4, auto, 250k +, DP TUNER, ISSPRO Performax's, BD trans, 6" lift, bilsteins, 37" nitto's on 20" welds, 4:30's, Warn hubs, 4" turbo back, muffler delete, 6637, ccv, OBA, 650 dash, '08 rear diff cover, '05 HeadLights, RiffRaff HPX + FRX, Pete's cover, 307 rwhp + 653 rwtq
07-19-2009, 11:17 PM
Accuracy By Volume
2003 Ford F-350
Wow, that looks good.
__________________
Adam
PAA #75
2003 F350 7.3 4x4 EC/LB FX4 4R100 104,000 miles
AFE II, Zoodad, Foil Delete, AIH Delete, 140v IDM, CCV, Leveled, DC FC-IIs, DP Tuner w/ 60t, 80e and 140a, OBA, WW, Isspros and a 6" black stack.
07-20-2009, 01:31 AM
2002 Ford F-250
Looks real good Mark. Both of those things are on my to do list...
__________________
Chris PAA MEMBER #90
2002 F-250 7.3L 114,000+ K&N Intake w/6637 & Pete's cover, MBRP 4" Turbo back, JW VB, Zoodad, AutoMeter Ultralite Boost & Pyro, DP Tuner w/80e 120r, 140x, CCV mod, ITP OBA, AIH delete w/boost, HPX, Foil Delete... Mods purchased & waiting for install: Big Poppa's Loaner Turbo
"Black smoke don't mean its broke!"
07-20-2009, 08:15 AM
Black Smoke
2003 Ford F-250
Looks good!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
07-20-2009, 08:44 AM
that is beautiful example of a 01 effie
well done Mark.
__________________
Brian
03 F250 XLT LB. Edge Evo , Dobinson 2" lift, 285/75/16 BF Goodgridge Muddies, pillar mount, Stewart Warner gauges, Foil Delete,Hutch with Pre Pump Filter,Walbro GFS-392, HPX, CCK, RR, Stealth CCV, AIH delete, Oilguard bypass, aFe Magnum Force Stage 2-PG7, MBRP 4" Turbo Back, Ceramic coated manifold,uppies and turbo exhaust housing
07-20-2009, 08:46 AM
Monitoring The Vitals
2003 Ford F-250
Sharp, nice job Mark...
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 132,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
07-20-2009, 09:17 AM
Looks really good Mark! Nice work!!
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks , 6637 w/,Custom Cold Air Intake ,
Autometer guages ,
DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
07-20-2009, 06:31 PM
Tip Coozy
Great job Mark that looks really good!
07-20-2009, 09:35 PM
Caution! Will Blow Smoke.
Looks good Mark. I have a grille that looks like that nice.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Ceramic/Kevlar Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
11-05-2009, 12:34 AM
Hey Mark,
Sorry to dig up an older thread but I'm about to install the exact same kit on my pickup. I was wondering what size tires you have on that truck in the pics?
__________________
Mike - 2004 F-250 V10 CC FX4 SRW
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
