Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-19-2009, 06:11 PM
anollmann anollmann is offline
Garage is empty, add now
anollmann is starting off with a positive reputation.
SYNC 2nd USB Port
Well, I finally found it while working on wiring up the video system (Arbitrator) in the console. The SYNC box is bolted to the bottom of the console, with the plug facing toward the passenger side. To get to it, pop off the trim around the front cup holders and around the shifter. Then removed the top paneling there that runs from the dash to the big center arm rest. There are then two screws holding the front of the console down. Remove those, along with the 4 screws on the sides. The front two are behind those little plastic covers and the rear two are exposed (just slide the seat forward and access from the rear) Then just lift up the back corner of the console and plug in your USB! I accessed it from the rear passenger door with the front passenger seat all the way forward.
Its nice having my iPhone wired up all the time and the primary USB still available for hard drive, thumb drive, or flash updates.
Just thought I would share!
Alex
__________________
Alex
2009 Expedition Limited
  #2 (permalink)
Old 07-19-2009, 07:29 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
I am seriously considering buying the Sync Add-on pack.
But it is $549 and requires Dealer installation.
vice a JVC or Kenwood unit that has the same functions, touchscreen, DVD...alot of other stuff.
how good is the Sync setup?
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 07-19-2009, 09:26 PM
I really like it. I don't use any of the voice stuff, just the iphone/ipod interface and the bluetooth phone. I've heard getting the "add on" kit is not as good as the original. I would suggest spending the $550 on a good bluetooth phone kit and an ipod adapter.
__________________
Alex
  #4 (permalink)
Old 07-20-2009, 12:00 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
I'm a big fan of using OEM if possible...usually less problems
I like the idea of plugging a 8 gig thumb drive into that hidden USB port and not have to worry about it again
__________________
  #5 (permalink)
Old 07-20-2009, 05:23 AM
Yes but in this case it is not truly OEM... Does the aftermarket kit include the microphones built into the mirror and the buttons on the steering wheel?
Forget an 8gb thumb drive, I've got a 320GB hard drive plugged in! Takes a few minutes to index but works like a champ
You really trust that dealership to install it???
Good Luck
__________________
Alex
  #6 (permalink)
Old 07-20-2009, 10:26 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Are you sure the add on kit is for the 2008? I heard only the 2008+ Navigator will work for the add on kit.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #7 (permalink)
Old 07-20-2009, 07:48 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
it says for 2008+ Ford vehicles.
if not, then I can throw it in the Stang. so not really worried about not being able to use one.
The add-on come with a speaker you install into your mirror or sun visor. then something gets put on the dash.
The install can actually be done by anybody, but you have to let a Ford Technician plug in a laptop into the USB port. Then they visit http://www.syncmyride.com and do some PC voodoo.
edit: so maybe it was wishful thinking. The add-on only seems to work on 2009 vehicles. and even then, if the 2009 model was produced in 2008, chances are it won't work.
well crap.
__________________
  #8 (permalink)
Old 07-20-2009, 07:57 PM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj is gaining momentum as a positive member of FTE.
heymrdjlive
I wish (yes this is a side note) that there was more MP3 accessories than for IPOD. Most all quality MP3 players use the open access communication protocol that windows media player stores music by. Even if you don't sync your music with WMP, an MP3 players OS most likely syncs by the same protocol when you turn it on, just like almost every digital camera stores images in a folder named DCIM. It should be easy for a carputer like the SYNC system to have just as much control over a normal MP3 player as a IPOD/IPHONE/ISUCK :P
__________________
2004 Expedition
Eddie Baur 4x2
5.4L 2v Triton V8
NEW: 2 3/4" pipe with Flowmaster Super 50 Delta Flow Muffler and 3.5"x18" echo tip WOOT
Upcoming:
Dual 16" Troyer performance fans
WAAG grill guard
Scanguage II
all corners air suspension
Tags
2005, 2nd, adapter, connector, expedition, f150, f250, ford, hdd, ipod, limited, port, sync, truck, usb, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
