Archived MS Buy/Sell/Trade Ads
#77
I saw some on Craigslist in Picayune a while back. Same style as mine. Where are you located?
#78
Hey guys. The following is a list of extra stuff I have. Prices are negotiable so let me know if anyone needs parts. I'm located in Meridian MS and I take trips down to the coast every now and then so I might be able to deliver within reason. PM me for pics as there are too many to post.
light blue hood 150
white hood 100
black hood 50
driver light blue fender 40
driver light blue door 100
pass door window 20
driver and pass lower door hinges 5
pass door latch and rod 10
pass door window channel 5
pass door window regulator 10
pass door interior latch 10
rear step bumper 75
c6 auto trans long tail
shaft w/cooling lines 2wd 200
steering wheel 50
steering wheel spacer 78-79 10
glove box door maroon/custom 20
351/400 exhaust manifolds 30
power steering pump with lines 30
and bracket 50
maroon ashtray 5
emergency brake actuator 20
silver gauge cluster cover 5
rear sliding window 20
light blue hood 150
white hood 100
black hood 50
pass door window 20
rear step bumper 75
steering wheel 50
and bracket 50
maroon ashtray 5
#80
What is the style and condition of the steering wheel?
Also, when you say passenger door interior latch, which part on this diagram is that?
Truck Parts and Truck Accessories
Thanks! I'll be through Meridian this afternoon and again on Sunday.
#81
PS pump
David, unfortunately it's just the old can style Ford. The steering wheel came out of the 79 Ford Ranger XLT. It looks like a boomerang inside the round part. Not sure what else I can tell about it other than it's in good shape.
#82
While at a local JY today, I found a good tailgate, 3 spd tranny, clutch, pp, zbar, etc. behind a 302, rear step bumper all on a 76 F100 if anyone needs one of these. Not sure on price but if you need one, let me know and I'll check.
#83
Along those same lines, I found this truck in Pass Christian:
http://truckstory.blogspot.com/2013/04/donor.html?m=1
He's asking $900 for the whole thing, but he's also willing to part out. It is a 76 Ranger 2wd with the 360 and an automatic transmission. I cant remember if it is a 100 or a 150. I have been to see it, so I may be able to answer questions about it. I can get you his number if you're interested. Lots of good parts still left. No wheels, tailgate, headliner, or seatbelts.
#84
I saw several dentsides between Meridian and West Point on 45 if anybody is looking for another project.
Also there is a first generation Lightning for sale on 53 between Poplarville and Necaise.
#87
I have dealt with a couple of individual parts trucks here on the coast. Haven't found anything in junkyards.
#88
I'm looking for the front passenger side parking light, for my 76 F100. The one above the headlight in the grille. I have yet to find one in a boneyard, and I may end up having to buy it online. If anyone has one please let me know!
#89
1976 F100 Custom
I am looking to sell my truck because I have found another one to buy that I want more. I am not a body man but can do the mechanical and thats about where I have left my 76 at.
1976 F100. 300 6cyl and C4 transmission.
New:
master cylinder
front brakes, rotors, bearings
rear brakes, spring kit and cylinders
fuel pump
water pump
oil pump
oil pan, valve cover and side cover gaskets
thermostat
Power steering pump and pressure hose
all new battery cables and solenoid
PCV valve
Tires
Work thats been done:
Floor boards have been cut out and replaced and also the floor has been rhino lined
Fuel tank cleaned out and all new fuel hoses
Bought new fuel sending unit but was garbage so bought a used one from benbuilder and now it works fine
Carb has been rebuilt
Motor was replaced- the original ran but made some noise so replaced with an engine from a 79
Swapped engine to durasparkII ignition.
Only rust that is on the truck now is in the hood and I have another to go with it. Also in the bottom of the doors but my body guy was going to cut it out and replace it. The bed has some surface rust but thats it. I have a non cracked dash pad that I had painted and also door panels that are also painted the same color. The seat still needs to be redone.
There is no where I have been afraid to drive this truck, it runs out fine. The ONLY reason I am getting rid of it is because I found a 71 F100 that I want. I like the body style a little more.
If you are interested send me a message. Oh I am asking $3000 but is somewhat negotiable.
New:
master cylinder
fuel pump
water pump
oil pump
thermostat
PCV valve
Tires
#90
1976 F100 Custom
New:
master cylinder
fuel pump
water pump
oil pump
thermostat
PCV valve
Tires
If you are interested send me a message. Oh I am asking $3000 but is somewhat negotiable. I can email updated pictures....thats all I have on here.
New:
master cylinder
fuel pump
water pump
oil pump
thermostat
PCV valve
Tires
