6.4 major problems
#31
#32
Yeah exactly Mick, what a headache it looks like. Glad these guys know what they are doing, most of the time.
#34
I have to ask, EGT of anything over 1200 max is horrible, isnt it? On big trucks at 900 its time to downshift. I can Haul aload grossing at 80000 lbs and on the hills out west very rareley hit 1000 egt temps. I would think, 1350 is at self detruct temps,
#36
For a 6.0, yes. You have to remember, when these trucks go into regen stock you can see your egt's in the 1400's. For those that have a stock truck, get something that you can monitor your egt's with. Think you will be shocked when your going 30 mph and see your egt's @ 1350+.....
#37
On the EGT's. I monitor using the Edge Insight and I get the 3 sensors in the exhaust and 1 reading which is real time.
Technically I don't know the exact location of the sensors but it's pretty obvious to tell the order of them in the truck.
In my experience, the engine runs very good and at its best efficiency when the temps are very hot. I try to make sure that the thing runs as hot as possible. Seems wrong but the way the thing is designed I really think 900-1200 is the sweet spot.
#39
#40
I have F450 at the dealer to but not that jurastic of a problem just injector pump replacement .Because it was throwing a code 0088 (fuel rail pressure to high)and going into a limp mode it took them 2.5 days to do it.But know they say a new part that goes with the pump that they put in is gauseing it do die when it gets hot .Ford tech guys say that this part has been modified but no one at dealer knew about it untill they checket with the tech guys .Know I have to wait till they get the new part in.I hope there not Lieing to me
#41
#43
Other than they say I can pick it up with the new motor on wednesday but that is to late I will be in Tennessee on wednesday for Riffraff east. So when I get back we plan to drive it around town for 2 days just to make sure all is well and see if they replace the DPF witch I think is clogged.
#44
#45
Sounds like Riffraff East is going to be a good time, have fun!!
