Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-19-2009, 10:42 AM
choppycam choppycam is offline
choppycam is starting off with a positive reputation.
Engine start end dead after few seconds...
Hi all!
I'm new here. I have just post my introduction before and now I need your help.
My brother and me have a Ranger 1994 with 4.0L 1993 engine. after the "swap" (loll), and some resolve problem, we have tried to start the engine.
The engine fire up but dead after few seconds: 2 or 3 max.
Someone know what the problem it would be? We have canceled the old anti-starter and no results...
Let me know if you have any idea!
Thanks!
Cam
  #2 (permalink)
Old 07-20-2009, 12:01 PM
TigerDan's Avatar
TigerDan TigerDan is online now
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Hi and welcome!
Are you showing a Check Engine Light on the dash, which would indicate that trouble codes have been generated by the computer? That's always the first place to check. I'm wondering if you might have a fuel starvation problem. When the engine dies, will it start right back up again (only to die again a few seconds later?) or do you have to wait some time before it will restart? Have you checked the fuel pressure? Have you verified that the fuel pump is working? You can do this by listening at the fuel filler with the cap off, when the key is first turned on the pump should run for 1-2 seconds to prime the system. It's possible that the Inertia switch has been triggered and needs to be reset (if you don't hear the pump running).
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 07-20-2009, 12:12 PM
Thanks TigerDan.
No check engine light.
When the engine dies, will it start right back up again (only to die again a few seconds later?): the engine start right back again.
I don't have check the fuel pressure, but I know that the fuel pump works, because I bought a know one and it works.
I will change the computer with my old one (because I don't have the small machine to reset error code).
I let you know ! Tnaks for your help!
Cam
  #4 (permalink)
Old 07-20-2009, 12:57 PM
TigerDan's Avatar
1968 Ford F-250
If you're not getting any codes, then resetting the computer is pointless. However, there are some codes that can be generated without triggering the Check Engine Light, though any serious enough to keep the engine from running should trigger the light. Here's how you can check the codes without a scanner:
http://fordfuelinjection.com/?p=13
Checking the fuel pressure is rather important, there could be other reasons why the engine may not be getting enough fuel to keep running (if that is indeed the problem.) And just because you have a new fuel pump doesn't mean it's working properly. The Fuel Pump Relay might not be triggering it correctly, the inertia switch I mentioned earlier might not be allowing it to run at all, the Fuel Pressure Regulator might be stuck open and not allowing the system to build enough pressure, even the fuel filter could be plugged. Any of these things, or even a combination of them could be keeping the system from operating at its needed 38-40 psi of fuel pressure.
And of course I could be totally off-base and it could be an electrical/ignition problem...
__________________
FTE Moderator
  #5 (permalink)
Old 07-21-2009, 09:35 AM
Thanks again TigerDan.
I will check all your new comments during the next week-end. I'm busy right now. Your concers are really important.
Cam
  #6 (permalink)
Old 08-02-2009, 09:45 PM
Hi all.
Actually, we don't have results. We not tried all yours idea... but something is in our mind... time to swap the truck with a 302 engine... and the idea is gaining.
Or, someone know is a 4.0L engine with carb exist?
So... the real problem actually it's to find time for to do the rest of test that we have to do.
Cam
  #7 (permalink)
Old 08-05-2009, 04:27 PM
TigerDan's Avatar
1968 Ford F-250
A 5.0 swap isn't too difficult, but there are a lot of little details involved. There are of course swap kits consisting of mounts and header to make the job a little easier (I made my own) and going carbed is simpler than staying with EFI but if you're up to the task, the EFI wiring isn't all that bad to deal with. I made mine all the more difficult by using a Mustang harness rather than buying an aftermarket engine swap harness, and am paying for it in wiring hassles that I didn't foresee...
__________________
FTE Moderator
  #8 (permalink)
Old 08-06-2009, 09:38 AM
I agree with you about the fact the little more difficult to swap an EFI engine. It's why we found an 302 carb engine. But we won't to find the problem for the 4.0L engine before, just for challenge.
  #9 (permalink)
Old 08-14-2009, 11:01 PM
93MTRANGER 93MTRANGER is offline
1993 Ford Ranger
93MTRANGER is starting off with a positive reputation.
4.0L Fix for startup then die problem
Hey,
I hope that you get this before you switch to the 302--which would be pretty sweet! I have a 1993 4.0L V-6 and had the same problem where it would start and then it would start to sputter and die. It turned out that the throttle body was dirty and needed to be cleaned with SeaFoam. I believe that you can pick it up at any auto parts store. My brother had the same problem on his 93 ranger and you just spray it in the throttle body and let it sit for a little bit and then start it up. Don't worry when the exhaust is a bit white and smokey-it's just burning that crap out. Cleans it out really good. If you don't want to go that route then just take a good look at the throttle body and if it's all gunked up then just clean it out to make it run smoother. Hope this helps.
93MTRANGER
  #10 (permalink)
Old 08-15-2009, 09:03 AM
Solve the problem with seaFoam... seriously... I'm suprised with this information. Why carbon crap can cause an no start engine? It's strange...
Thanks for your help. Cam
  #11 (permalink)
Old 08-15-2009, 10:39 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
Check the fuel pressure at the schrader valve on the fuel injector rail. Your description of the way the engine runs for a few seconds and then dies makes me think the fuel pump is not running after the engine starts. Some vehicles have a pressure switch that disables the fuel pump if the oil pressure is not maintained. If this switch were defective, you would get fuel pressure to the injectors, and they would have enough pressure in the fuel line to inject fuel for a few seconds. Just like what you describe. The passenger cars had a multifunction box that ran the fuel pump, and the cooling fans. It checked that the engine was running, either oil pressure or ignition pulses, and would disable the pump if it thought the engine was not running.
Where are you posting from?
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #12 (permalink)
Old 08-18-2009, 02:58 PM
tom
I think you have the best information since the beginning... I already ear this kind of information but not with this precision. I'm glad to know that. We will check if we can do something with this... I think yes!
THANKS !!!!!
Cam
Tags
2001 , 99 , dead , dies , efi , engine , ford , long , motor , ranger , running , runs , seconds , start , stops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
