Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 07-19-2009, 01:40 AM
John with beastly 302 John with beastly 302 is offline
Garage is empty, add now
John with beastly 302 is starting off with a positive reputation.
Question Motorcraft Cetane Booster and Performance Improver
I have just recently started to use this stuff and I had a couple of questions. On the back of the bottle it says to use 4 ounces to every 30 gallons or something like that. I have a hard time believing that 4 ounces of a kerosene naptha mix raises the cetane rating of 30 gallons of diesel considerably. I mean if this stuff is that potent then how can they sell it to the public. Lately I have been using a half a bottle to each fill up on my tank.
So is there risk of using too much additive? And if So how much is too much? I am almost tempted to use a whole bottle for a complete fill of the tank. Does using this much cause any kind of damage to the fuel system via o-rings or injectors?
I do not know if anyone has mentioned it but there is a guy on you tube that calls himself Powerstroke Help. He has interesting videos on the 6.0. In one video he stated that the 6.0 was designed and engineered in europe were the quality of diesel is very high. He says the fact that our diesel is lower in cetane was overlooked in the design of the 6.0. I am sure someone has said it before but the lower the cetane rating the more particulate is generated so maybe this additive is worth it. I just wonder how potent it is?
__________________
1991 HD F-250 XLT Lariat
Fire Breathing 460 V-8 E-4OD
RIP 94' F-150 4X2 5.0 MAF 4R70W Super Cab Shorty Green W/ tan accent 2" front lift Flowmaster 40 3-20-94 to 6-8-05 First truck and I hit a bridge reaching for the cellular
  #2 (permalink)
Old 07-19-2009, 08:16 AM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a very good reputation on FTE.ljutic ss has a very good reputation on FTE.ljutic ss has a very good reputation on FTE.ljutic ss has a very good reputation on FTE.
I would advise you to follow the instructions on what they recommend. As far as the cetane levels of this country, I don't know of any federal standards the refineries have to meet to call it diesel. In Pennsylvania where I live, fillup stations don't have to advertise cetane numbers, but I have seen a few (Hess) stations that did.
  #3 (permalink)
Old 07-19-2009, 08:25 AM
labwillow labwillow is offline
labwillow is starting off with a positive reputation.
I use the motorcraft stuff exclusively in the winter in both my diesels. I use 4oz for each fillup 20-35 gallons and I have had no problems. I use the winer blend of the anti gel and as long as I remember to use it at every fillup I have no gelling issues. I tried other stuff and I found I had the best luck with the motorcraft stuff. It is also a good deal $14.00 to treat 120 gallons. Last winter I had not used my pickup in a while and my wife took it out of the garage and went to work on a day it was -20 needless to say I nhad to bring my other diesel to her and play the warm and wait game with my pickup. I dumped a whole bottle of the motorcraft stuff into a half tank of fuel. After I got the truck running right and it warmed up it felt like it was on steroids.I assumed it was due to the high concentrate of cetane booster in the tank.?
__________________
'07 F350 4x4 6.0 torqueshift 4.10LS Dually SCT w/Matt's tunes, 4"MBRP, Cat Delete
'04 F250 4x4 xlt crewcab 6.0 auto,K&N, Muffler delete, SCT running spartan agg st eco,innovative mld tow w/brake
'76 CJ-5 2.5" lift 32x11.50 Swamper SX's
  #4 (permalink)
Old 07-19-2009, 11:16 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
2006 Ford F-250
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Bill Pounds
Quote:
Other brands of additives are also used in similar concentrations, so Motorcraft isn't out there by themselves.
Does the additive say how many cetane points it adds at the recommended concentration? If not, maybe you can find a reference out on the internet.
My point is, generally the diesel we buy is most likely to be around 40 cetane. Our trucks were designed to run on 45 cetane. Online references I've found in the past say that anything over 50 cetane is of no value, and between 45 and 50 is a diminishing value. So, I try to shoot for about 45, assuming the fuel I buy started out at 40. An assumption that is impossible for me to verify, but it's the only baseline I have. I use Diesel Kleen in a concentration that should give me a gain of 6 cetane points.
If you can find the info on your Motorcraft booster, you could shoot for the same thing.
__________________
Folks call me Bill. Why, yes, it is a 6 liter. Your jealousy is showing.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back (w/CAT),Edge Insight CS,Blue Spring,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto,'08 Diff Cover,Upfitters Retro-fit,Coolant Filter,Custom Man Steps,Keystone 2011 Cougar 278RKSWE,2012 Fusion SE
  #5 (permalink)
Old 07-19-2009, 12:04 PM
scottman70's Avatar
scottman70 scottman70 is offline
scottman70 is gaining momentum as a positive member of FTE.scottman70 is gaining momentum as a positive member of FTE.
Where do you purchase you Motorcraft Cetane Booster? Is there an online link that is cheapest?
  #6 (permalink)
Old 07-19-2009, 12:21 PM
Quote:
I get it from a local dealer for about $6 dollars a bottle. I'll have to some research as to how many points this stuff raises the cetane .
__________________
  #7 (permalink)
Old 07-19-2009, 12:38 PM
ljutic ss's Avatar
I buy it in gallon cans at the dealer.
  #8 (permalink)
Old 07-19-2009, 12:54 PM
According to Motorcraft this is what the cetane booster and performance enhancer is made of.
Chemical Concentration
HYDROTREATED LIGHT
DISTILLATE (PETROLEUM) 60%-100%
2-ETHYLHEXYL NITRATE 15%-40%
NAPHTHALENE 0.1%-1%
1,2,4-TRIMETHYLBENZENE 0.1%-1%
I would think that the distillate is probably kerosene or something of the nature. But I haven't a clue as to what 2-ETHYLHEXYL NITRAETE is or for that matter what the other two ingredients are?
__________________
  #9 (permalink)
Old 07-19-2009, 01:14 PM
An interesting link for 2-ETHYLHEXYL NITRATE. http://www.sae.org/technical/papers/981364
Also a definition of NAPTHALENE http://en.wikipedia.org/wiki/Naphthalene
And a definition of 1,2,4-TRIMETHYLBENZENE http://en.wikipedia.org/wiki/1,2,4-Trimethylbenzene
__________________
  #10 (permalink)
Old 07-19-2009, 02:09 PM
juneau76's Avatar
juneau76 juneau76 is offline
2010 Ford F-150
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
There are a few places that sell it. http://lmgtfy.com/?q=Motorcraft+Ceta...mance+Improver+
Motorcraft doesn't list the actual Cetane gain if you use it:
Note: This ultra-low sulfur formulation can be used in engines required to meet 2007 emissions requirements (e.g., Ford's 6.4 L diesel engine) and is backward compatible as well (i.e., can be used in Ford's 6.9 L, 7.3 L, and 6.0 L diesel engines).
Ultra Low Sulfur Diesel (ULSD) Compliant
Specially formulated for diesel engines to combat the effects of poor-quality diesel fuel
Boosts the Cetane Rating (fuel ignitability) of diesel fuel for improved starting performance
Increases power
Smooths engine operation
Improves fuel economy
Adds lubricity to fuel to reduce engine wear
__________________
Brad
2010 F-150 XLT Supercrew 4x4 5.4L
2013 Explorer Limited (The wife's family truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #11 (permalink)
Old 07-19-2009, 02:27 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
bpounds is "right on target" ............ Ford is now saying that 45 is the minimum recommended CETANE level. The minimum specs at the pumps in the States is 38 to 40.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #12 (permalink)
Old 07-19-2009, 04:07 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
I use PowerService and use it at "double-dosage" rates at every fill-up.
I have spoken to PowerService several times over the years and they state up to "double-dosing" provides a benefit... but after that, the costs outweight the gains.
No fuel additive will make bad diesel fuel great fuel... but some or double dosing is better than none at all.
I personally year-round and at every fill up. I too agree that a few ounces per fill-up is to little to really help... so I double-dose.
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #13 (permalink)
Old 07-19-2009, 09:12 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke MoyockPowerstroke is offline
MoyockPowerstroke has a good reputation on FTE.MoyockPowerstroke has a good reputation on FTE.
Let's not forget about Stanadyne. I definately see 2-3 mpgs improvement. My 6.0 loves it like katnip.
__________________
Real Trucks Don't have Spark-Plugs '05 6.0L, 101k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto, Coolant Filter, Raybestos PS Filter, ZooDad, HighIdleMod, BullyDog 4" (BullyDog ate Kitty), VXCF9 Strat Code, Edge Insight gauges, Fuel Press Gauge, SJ 4" Lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Diff Cover, Upfitters, Mobil1 Syn 5W-40, Stanadyne Perf, Prodigy Brake Controller, Satellite radio, Lund Moonvisor.
  #14 (permalink)
Old 07-19-2009, 11:18 PM
Got Diesel?
Quote:
Yep... good stuff indeed.
I don't think anyone was forgetting about but rather the question was how much is necessary or if extra dosing was required.... how much is too much??
That is why I posted that I have spoken to PowerService on 2 or 3 occasions and would recommend that other due or call their preferred choice of additive company.
I double-dose since this is what PowerService stated I could do and the benefits would equal the gains... more than double-dosing would be a waste (is what they told me).... but single-dosing is good and provides all the lubrication one needs when following their labeling.
__________________
24" Wiper Blades
  #15 (permalink)
Old 07-19-2009, 11:31 PM
bismic's Avatar
I personally like Stanadyne. But I think that "single dosing" stanadyne is about the same cost as "double dosing" power service. I believe you pointed that out in a past post BBC. I believe that either of these approaches offer excellent benefits. So does the Ford Cetane Booster additive (which is rumored to be Stanadyne re-packaged).
In the past some folks have seriously questioned the need for fuel additives. They say that there are relatively few issues that people have with fuel quality. I started saving posts on complaints of fuel quality awhile back and actually got up to quite a few. I have since deleted them since my spreadsheet of 6.0L reference material (and links) is almost 10 MB now. I firmly believe that bad fuel is more common than most people would like to believe. Maybe w/ the ULSD these incidences are becoming fewer - only time will tell.
My point is - you may or may not ever really NEED fuel additives. Also, if the fuel is REALLY BAD, then even fuel additives will not save your fuel system. For the situation where you get lower cetane fuel, some slight water content, higher chain hydrocarbons that tend to gell, fuel additives are a big help.
__________________
Mark
Tags
22gal, 404, 60, additive, booster, buy, cetane, egr, firepower, ford, improver, motocraft, motorcraft, performance, pm, stanadyne, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
