aod vs c6 vs. e4od ? - Ford Truck Enthusiasts Forums
Old 09-30-2000, 08:32 PM
billyb billyb is offline
billyb is starting off with a positive reputation.
first , thanks for putting this section in!!
now , my question is this, i converted mmy 88 f150 to 4wd. i used 3 speed with overdrive. after using for a few months, i am thinking about swapping to auto box.
what do you guys think of the aod, the e4od, and the unbeatable c6. the only reason for not going right to a c6 is mileage. is the difference on highway and around town with overdrive really worth the effort and expense?
also does anyone know if a t18 from 2wd is too expensive to make ready for hooking to transfer case? i am hearing that main shaft has to be changed and that cost is not worth effort.the granny first gear in t18 is also something i keep thinking i might not mind having.
any input and similar experiences would be appreciated before i start down wrong road!
Old 10-02-2000, 09:55 PM
russe russe is offline
russe is starting off with a positive reputation.
Just a bit of what I know. The aod and the e4od are essentially the same trans. One has a governor and the other is electronically acuated (e4od). Overdrive gears tend to lower highway rpm by about 200-300. My choice for serious towing or off road would be c6. For around the town and light work, aod or e4od. Personally though, I think I would try to put a zf 5 spd in that truck.
Old 10-03-2000, 09:07 PM
thanks for info russ. i did look into zf5 speed but it seems that all the ones i found have internal slave cylinder( 1990and later). i am concerned with how to adapt my master cylinder to this? i thought about changing to later master!
i did see some posts referring to this last spring, but can't recall the concensus on how to handle this.
aalso, what is fair price to pay for unit? thanks again for info.
Old 10-04-2000, 04:43 AM
DannyP DannyP is offline
DannyP is starting off with a positive reputation.
As far as price on a ZF, you are probably talking at least 800 bucks for a junkyard model up to at least a $1,000 for a rebuilt. That is what is
keeping me from doing the swap right now. I found one from an individual in the next state in some classifieds for $650, but am leary about spending that much without some kind of guarranty. Besides, the drive I would have to make to pick it up eats up some of the savings. Like you, I am wondering how much gas savings there would be with the overdrive, I posted that question several months ago, but know one had any answers. I'll just stick with my T-18 for now I reckon.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, T-18 but looking for a ZF. 3.55's.
Old 10-13-2000, 05:06 PM
StrangeRanger StrangeRanger is offline
StrangeRanger is starting off with a positive reputation.
The AOD and the E40D are most definitely not the same tranny. The AOD has been replaced by the AOD-E, which is now called the 4R70W. Even in it's present, vastly improved form it is smaller lighter and weaker than the E40D, which is now called the 4R100. If you're willing to put in stand alone electronics to run the tranny, the E40D is the way to go in a truck. See http://www.baumannengineering.com/ for info. If you want to avoid the electronics, the best source for (mechanical) AOD parts and technology is http://www.artcarr.com/
Old 10-13-2000, 07:09 PM
ranger, thanks for info on baumann. i will check the site. that sounds like what i am after.
Old 10-17-2000, 02:03 PM
micnet micnet is offline
micnet is starting off with a positive reputation.
Old 11-20-2005, 04:46 AM
forsaken forsaken is offline
forsaken is starting off with a positive reputation.
hey billlyb i think you should sell that AOD trans to me i need it for my truck i have been looking for one for about 3 months now and can not find one close by let me know e-mail me at jetm7885272002@yahoo.com thanks
Old 11-20-2005, 11:08 AM
wycowboy's Avatar
wycowboy wycowboy is offline
wycowboy is starting off with a positive reputation.
I might have a e4od for sale.!! if any one isinterested.. I'm planning on putting a zf5 in my f350 and will have the e4 lying around ..MP me if you want it..J
Old 11-20-2005, 05:28 PM
well i need an AOD
Old 11-25-2005, 08:13 PM
chopsley chopsley is offline
chopsley is starting off with a positive reputation.
I would be interested in that E4OD. My friend has been looking for one.
Thanks, Craig
Old 11-26-2005, 06:29 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome chopsley, to Ford Truck Enthusiasts!
Enjoy FTE....see you on the boards.
Old 11-26-2005, 07:38 PM
will someone tell me if there is anyway that i can use something other than an AOD i am haveing a really hard time trying to find one down here in oklahoma please HELP!!!!!!!!!!!!!!!!!!
Old 02-26-2010, 03:57 PM
slayerman54 slayerman54 is offline
slayerman54 is new and has a neutral reputation at this point.
[quote=DannyP;546485]As far as price on a ZF, you are probably talking at least 800 bucks for a junkyard model up to at least a $1,000 for a rebuilt. That is what is
I know I'm just bragging but I picked up a ZF5 with 70K for $250. It was traded into a dealership during the C.A.R.S. program and I just waited for it to be shipped to the junkyard and then jumped on it. I got the tranny, t-case(1356), both driveshafts, master and slave cylinders, good flywheel, almost new clutch, starter, shifter, floopan, crossmember, and a good looking cab carpet for $250. Everything went together perfect and the truck(96 F350/460) shifts excellent.
Old 02-26-2010, 11:34 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
The "every 5 years" thread....
1978 F-250 upgrade on a budget help bulldogcountry1 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-13-2017 12:11 PM
2Wd E4od with divorced transfer case pm042070 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-03-2014 09:30 PM
460 C6 to AOD Conversion TonyJestis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 09-19-2013 08:27 AM
2wd truck: T19 + 2.75:1 rear = poor man's overdrive? psquare7575 1973 - 1979 F-100 & Larger F-Series Trucks 11 09-01-2012 01:20 PM
1991 5.0 Liter Motor.....Troubleshooting...Need Help Please! Solomon_Man Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 09-14-2010 12:23 PM
Tags
150, 2wd, aod, aode, c6, comparison, e40d, e40daod, e4od, ford, sale, swap, switch, transmission, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
