Alternative Headliner Setups
Hey after tearing out my trashed headliner I am looking to replace with....something. Definatly do not have the money to buy a standard replacement so I am hoping to dig through the depths of knowledge here and see what others have done and how you did it......as long as it's cheap and clean....pics are helpful as well.
My original one was trashed from too much mud and several washes. I used the stock cardboard to make a template and then I padded it with some thin foam. I read that I could make some designes with another layer of foam. I came up with this:
Tha material itself was not expensive, I made friends with a local upholstery shop and used a scrap piece that I picked up for cheap.
Probably have about 20 bucks in the whole thing.
Nah, poor old Stetson is far more expensive than my headliner, but it keeps my bean dry and stays put if I am not wearing it and things get bumpy.
Funny though.............
Thanks for the compliment. I did not expect the letters to be that big or bold, and would do it different if I were to do it again. This one works Ok.
I am in the same boat. I was in Lowes the other day and I found this fiber board. It is the same stuff they use as backing for dry erase boards. It was 8X4X1/8" thick. It is flexible, and paintable. I am just going to cut mine from the template of the old headliner, use 3M adhesive to glue some vynle to it, and then mount it as usual. It should be a great replacement. Plus, it was only 7 dollars.
Also, if you have it in your budget, throw some dynamat up there on the roof. It quiets it down a lot!
