Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 10-23-2009, 03:03 PM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Why so many dents?
My truck has none. Yes, I know it's 31 years old...but it doesn't have any. But of course, I'm battling with rust.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #47 (permalink)
Old 10-23-2009, 04:40 PM
hotroddually's Avatar
hotroddually hotroddually is offline
1974 Ford F-350
My Garage
hotroddually is gaining momentum as a positive member of FTE. hotroddually is gaining momentum as a positive member of FTE.
ranger she looks good! jugding by your other 2 "toys", it will be real fine when you are done.
__________________
74 f350 4x4 dually 428scj,-HOOF BEATS ARE LOUDER THAN HEARTBEATS!
2001 ranger xlt supercab 4x4
2008 ford escape xlt
2006 harley davidson softail fxst
  #48 (permalink)
Old 10-23-2009, 06:16 PM
ranger429 ranger429 is online now
ranger429 is gaining momentum as a positive member of FTE. ranger429 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Jermafenser View Post
Why so many dents?
Honestly Chad I have no idea.
Quote:
Thanks.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
Vote in the FTE final round: http://www.ford-trucks.com/forums/90...nal-round.html
  #49 (permalink)
Old 10-23-2009, 07:28 PM
460/5's Avatar
460/5 460/5 is online now
460/5 is starting off with a positive reputation.
maybe because its a "dentside"... ha! i made a funni!... not.
__________________
Trey, aka Stretch, aka Slim, aka Shorty, aka Seven-Footer, aka Daddy Longlegs.
'91 F250 red long box super cab w/ 460, 5 speed, 4x4.
'76 F100 tan custom single cab short bed w/ 360, 4 speed, NP205 4x4.
'78 F150 white single cab long bed w/ 400, C6, NP205 4x4.
Imagine what I could do if I had all my brain cells.
  #50 (permalink)
Old 10-23-2009, 08:26 PM
alconk alconk is offline
alconk is starting off with a positive reputation.
Why so many dents?
It could have started life like mine. A maintenance vehicle... It has 0 rust but every panel has a dent in it somewhere. Oh well, rather have dents than rust.
  #51 (permalink)
Old 10-23-2009, 08:31 PM
Yep dents are simple to fix, rust sucks.
__________________
  #52 (permalink)
Old 10-27-2009, 05:08 PM
Some more work on the crew.
I found the cheap nutsert tool at Menards, 9 bucks, than Buck.
First thing I did was made a template of the old nutserts.
Transferred.
Installed. When you are installing the nutsert make sure to put some oil on the threads, it makes it much easier to crimp down.
Finished.
Today I got the bed seperated.
The shiny part is 5 holes in the back of the cab I welded up.
Practically rust free for a 30 year old truck.
__________________
  #53 (permalink)
Old 10-27-2009, 06:22 PM
It must have spent nearly all of its life in Wyoming. I was born and raised there.
Much of Wyoming is dry. Big Horn is almost a desert. Yes, desert in Wyoming.
Curious - what's the DSO code on the turd?
__________________
Chad
  #54 (permalink)
Old 10-27-2009, 06:36 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Dang - that's rust free?
I have seen a lot worse for sure but that is a "rusty" frame here in CA...
Still - I'm sure you'll make it all purdy again!
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #55 (permalink)
Old 10-27-2009, 06:37 PM
Don't know Chad, have to get it next time I'm at the shop.
It must of been in the dry part of Wy. The body, other than dents, was literally rust free. The guy that had it in Mi. owned it for 2 years he told me.
It's all on the surface Chase, probably picked up when it lived in Mi. nothing severe at all on the frame.
__________________
  #56 (permalink)
Old 10-27-2009, 06:40 PM
1974 Ford F-250
Just looks a bit pitted where it was sand blasted. Frames on the trucks I have picked up are all still really smooth. Like I said though - still much better than many I have seen from back East, etc.
__________________
1970 Ford F250
  #57 (permalink)
Old 10-27-2009, 06:45 PM
Um that hasn't been sandblasted Chase. The 2 dark spots on the top of the frame rail and the crossmember have been hit with an air scaler. I knocked some rust scale build up off. The rest of the rails are fine.
One of these.
__________________
  #58 (permalink)
Old 10-27-2009, 07:19 PM
1974 Ford F-250
Pics aren't showing up now so I can't have another look, but it looked like part of the frame was silver like it had been blasted and other part looked like the normal surface rust color.
Either way - it is what it is. If you say it's fine - then I'm sure it is.
__________________
1970 Ford F250
  #59 (permalink)
Old 10-27-2009, 10:54 PM
Living in the bone-dry desert year around, the factory coating will be intact after washing the dust off.
In semi-dry climates, the coating will fall off from the seasonal changes/perception revealing bare metal. It will get some surface rusting but hardly enough to pull hair out over.
Frames that are flaking off should be worrying you enough to prevent it now!
__________________
Chad
  #60 (permalink)
Old 10-28-2009, 12:45 AM
460/5's Avatar
i, being the campus redneck, am helping a guy fix the breaks on his chebby. the truck was and always has been a montana truck. the only parts of it not rusted is made of plastic or glass!! i advised him to get new drums for the rear before they crumble inside his wheel! when i hit it to knock it loose and take it off, it showered whole chunks of the cooling fins off...
__________________
Tags
1973 , 1979 , 4x4 , 76 , 79 , ac , build , cab , crew , f250 , ford , pics , sale , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
