Interior plastic paint to match factory plastic??
Old 07-18-2009, 03:36 PM
phoneman91's Avatar
phoneman91
phoneman91 is offline
Does anyone know of a source to get paint for the dash that will match the original paint that Ford painted the dash at the factory??
I don't want to use a generic paint-I dont want to have to repaint all of the interior plastic parts of my truck-I just want to do some touch up of the original factory paint on the dash. I need a perfect match.
My truck is a 1992 F150 with the factory "Granite" interior color-Ford calls it code "J" on the VIN sticker.
Old 07-18-2009, 04:51 PM
lsrx101's Avatar
lsrx101
lsrx101 is offline
Dupli-Color makes vinyl/plastic paint that is available almost anywhere. In my experience it rarely matches, though.
I've had the best luck with SEM brand paints for interior parts. Check with a local automotive paint store. It's about $13 per can.
I replaced some interior parts recently with aftermarket pieces and used the SEM product on everything else. (Interior color change, Light blue to dark blue). The match was perfect. On your original parts, you may not get a perfect match due to fading of the original pieces.
The SEM product sprayed and laid out great too. You could almost just throw the can at the parts and it would look good.
Don't forget to use the recommended adhesion promoter.
Old 07-19-2009, 09:29 AM
uncle.stosh's Avatar
uncle.stosh
uncle.stosh is offline
I'll second SEM products.
My local supplier can mix up any color of SEM that you need. Take a piece of your interior with you and they should be able to color match it with their computerized system (if they have one).
Old 07-21-2009, 01:34 PM
girlwithatruck's Avatar
girlwithatruck
girlwithatruck is offline
One more vote for teh SEM products. I've been using them (and their prep system) on the interior plastic and vinyl finishes on my f100 and they look fantastic.
Old 07-21-2009, 02:24 PM
ghunt's Avatar
ghunt
ghunt is offline
FWIW, I used the blue duplicolor vinyl/plastic paint on my pillar pod when I installed it. It matches the other blue plastic in my interior almost exactly. I was pretty happy with it.
Old 07-21-2009, 02:46 PM
phoneman91's Avatar
phoneman91
I found out that the Granite J code that matches the 92 and 93 F150 interior dark grey has PPG code of 34611 (semi gloss) or 34685 (Low gloss) UCV2-1357. See this webpage:http://www.tcpglobal.com/aclchip.asp...truck-pg03.jpg
SEM will also make this interior paint-but only at a quart minimum-or in a spray can as special order.http://semproducts.com/?home=1
www.paintscratch.com will be willing to make touch up bottle of it or spray can or larger amount. I have done business with this company before and the paint is always a perfect match.
Old 04-27-2016, 10:14 AM
Coach66's Avatar
Coach66
Coach66 is offline
The interior color paint/dye from LMC truck did not match well at all on my 2003 F150. Med Dark Parchment was no where near the factory. I did have better luck with medium parchment, but still different enough to notice.
Old 04-28-2016, 07:59 AM
JWA's Avatar
JWA
JWA is online now
Received 1,378 Likes on 1,093 Posts
The larger PBE suppliers will also have small aerosol canisters for their mixes too. Spraying much like rattle cans you get a much nicer finish.
BEEFKING69
01-29-2018 03:07 AM
DieselCamper
05-24-2017 03:01 PM
mOROTBREATH
15
02-21-2017 06:36 PM
Ford F834
38
10-08-2016 08:26 AM
Gregxlt
2015 - 2020 F150
06-25-2016 08:52 AM
Quick Reply: Interior plastic paint to match factory plastic??
