Need a tach for diagnostic work - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 07-18-2009, 04:34 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
I'd like to find a good underhood tach that will read numbers like in .25 or .50. I'm guessing nobody makes analog ones anymore although either will be fine. I need to adjust my RPMs in the ol' truck. It has a horseshoe bracket for the coil, so alligator clips make it impossible to clip on.
Nothing too expensive. Used is OK.
Any suggestions? Thanks.
Old 07-18-2009, 04:41 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
You should be able to find the old tach & dwell meters , There great for setting idle & adjusting carb ....I have an old snap on one that works great , its about 30 years old .. LOL ... Lew
Old 07-18-2009, 10:20 PM
Cool.
I only wonder how accurate they are anymore after use and all these years?
Old 07-18-2009, 10:22 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Use the built in zero set screw, and they're as accurate as when they were new.
Old 07-18-2009, 10:55 PM
That's right. Assuming there's one...off to to yard sales / flea markets tomorrow for a new one.
Old 07-19-2009, 02:38 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
The Actron one they sell at Autozone and Advance Auto is inaccurate out of the box, even using the zero screw.
I ended up buying a $99 digital timing light with tach for my work, comes in handy since it works on 2 cycles too.
Old 08-03-2009, 07:02 PM
I scored a Mac Tools ET-360 - dwell, tach, voltmeter, and ohmmeter. It came with a Ford horseshoe adapter! Perfect! It also came with its manual and etc in its box.
Cleaned, set the zero-out, and put in a new battery. Works beautifully.
Factory tach rowdyredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-03-2013 11:45 AM
Tach Install ALedbetter1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 06-26-2013 06:14 PM
I NEED A TACH!!! wreckinball Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 02-10-2011 12:03 PM
Found a Tach today but... 81Bronk36 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 02-15-2010 11:20 AM
Tach/Dwell meter--how to hook up? cole_boy Garage & Workshop 9 01-29-2003 08:45 PM
Tags
adjust, atlanta, dwell, et360, ford, georgia, mac, meter, set, tach, tachometer, tools, toolstachdwellohmmeter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
