Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-18-2009, 11:13 AM
miknlsa miknlsa is offline
miknlsa is starting off with a positive reputation.
2007 Odometer backlight not working
It appears the odometer backlight problem has been around for a long time, aon many models. Does anyone have anyhting on the 2007 f150 Supercrew? Just had the engine replaced under warrenty at 35600 miles. Just as soon as I get 50 miles out of warrenty the the odometer light goes out.
  #2 (permalink)
Old 07-18-2009, 04:03 PM
nascar88ford nascar88ford is offline
1987 Ford F-150
My Garage
nascar88ford is starting off with a positive reputation.
It probably is the bulb behind the odometer. First unplug the battery. After that, just remove the two screws right above the gas and brake pedal and pop off the knee bolster. Then remove the two screws where the top of the knee bolster pops in. Grab the top of the plastic around the instrument cluster and work it out gently. It is just held in with clips. This will expose the cluster. It is held in by 4 screws. Remove them and unplug it from the truck (two plugs from the top), unclip the PRND21 (if a column shift) switch and pull it out. Flip it over and figure out which bulb is blown and replace it by twisting it out.
Hope this helps,
-Matt
__________________
2005 F-150 STX Reg. Cab 4x4 4.6 Silver
1987 F-150 Reg. Cab 4.9 Auto Red 250,000
  #3 (permalink)
Old 08-07-2009, 07:56 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
most excellent...thanks!
  #4 (permalink)
Old 08-11-2009, 06:57 AM
n5926g's Avatar
Quote:
Hope this helps,
-Matt
Excellent procedure.Did it in about 20 minutes.Even had a spare lamp here in the garage...Thanks!
  #5 (permalink)
Old 08-11-2009, 02:26 PM
1987 Ford F-150
My Garage
I'm glad I was able to help. I know all of this because I just upgraded my stock (no tach) cluster with one out of a FX4. I had to take it out a couple of times. I love how Ford put the plugs on top of the cluster with those nifty little clip things. Makes life alot easier!
-Matt
__________________
  #6 (permalink)
Old 08-11-2009, 02:32 PM
n5926g's Avatar
-Matt
Yep...Had that little bugger in a spare lamp drawer in the garage...While im not planning to tear into my baby for awhile,I would like to have a cluster with tach at some point in the future.Ive also got a Pioneer aftermarket(with remote control) in the truck(sounds great)..it was in it when I bought it,but im a stickler for OEM.Might try to find an OEM dash unit in the future as well.....Thanks again bro!
  #7 (permalink)
Old 08-11-2009, 09:10 PM
1987 Ford F-150
My Garage
Ebay is your friend if you want to do that upgrade, or find an OEM radio. I'm not 100% sure if the V6 & V8's clusters are interchangable. I'm pretty sure they are. Any F-150 with a manual transmission in this gen. truck will have a tach. All you have to do is switch the PRND21 switch and the blank plate on the other cluster. Make sure you get one with, or close, to your current mileage. Mileage changes can cost big $$$ (up to $350+). Here is a link just to give you an idea...
http://www.ford-trucks.com/forums/86...er-change.html
AND, one last thing. Does your truck have cruise since it's an XL? If not, get you a steering wheel off of Ebay with the cruise control buttons and take you a trip to the local dealership and have them install and activate it! You will have cruise. The buttons and indicator will light up. Since these trucks are drive-by-wire, you don't need all the other stuff...
-Matt
__________________
  #8 (permalink)
Old 11-24-2009, 03:20 PM
F150newbie2007 F150newbie2007 is offline
F150newbie2007 is starting off with a positive reputation.
Quote:
I had the same problem on my 2007 Supercrew. I followed the directions as you did. The biggest issue was trying to pop off the cluster cover. Geez...... it wasn't as easy as "work it out GENTLY". I really had to pull...not knowing where the clips were I thought the whole thing would crack in my hands until it finally did really POP out. Fortunately no damage. You had a spare bulb on hand? I have never seen such a bulb before. My Ford dealer doesn't have one so I ordered 2. I hope to have it tomorrow and lets just hope the reassembly goes back in as easily??? as it came out.
Thanks,
Tom
  #9 (permalink)
Old 11-24-2009, 03:39 PM
partsguyed.com's Avatar
partsguyed.com partsguyed.com is online now
OEM BABY
partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold partsguyed.com is a splendid one to behold
there appears to be 11 bulbs back there.
6 black socket ones(dial illumination) 13B765A = YL3Z13B765CA
and
5 grey socket ones (indicator illumination) 13B765B= YL3Z13B765DA
Ed
__________________
Join us at the next Riffraff/Partsguyed II East event details.......
NEW UPDATED DESIGNED ESP WARRANTY PAGE CHECK US OUT Y2K-ESP
WE DELIVER WHAT OTHERS ONLY PROMISE! CONTACT US
  #10 (permalink)
Old 11-24-2009, 05:59 PM
n5926g's Avatar
Quote:
Thanks,
Tom
Actually MY spare bulb was out of a cluster for a DSM(Mitsubishi Eclipse)...these seem to pretty common even if the dealership didnt have one.When I got my 07(about 6 months ago) my backlight was out as well.Kinda wondered if I could do a retrofit with a High Intensity LED,and dropping resistor..but after seeing how easy the replacement was I figured it wanst worth the trouble...Cheers!
__________________
Air Transport Radar Tech
Tags
2001 , 2003 , 2004 , 2005 , 2007 , backlight , backlighting , cluster , f150 , ford , gauge , light , odometer , problem , trip , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
