Solenoid Hookup? Is this right? - Ford Truck Enthusiasts Forums
Old 07-18-2009, 04:52 AM
rchawaii's Avatar
rchawaii rchawaii is offline
rchawaii is starting off with a positive reputation.
This post is in reference to overheating of wires on the solenoid and positive battery terminal upon starting or attempting to start.
1975 F100 2wd
I cant post a pic so Ill ask in a succint (hopefully manner)
Solenoid.
Left side terminal to battery positive
Left side terminal to fusible link, to harness (Front)
Left Side (Yellow) to Wiring Harness (Rear)
Left side Terminal (Red Wire) to inside firewall..
"S" to Red wiring harness(Rear)
(I) to Brown wiring harness (rear)
Right terminal black wire to starter
Battery to ground to motor
No ground on starter, or engine to frame (This needs to be rectified I Know)
No heat shield on starter (yet)
All new: ign Module, solenoid, volt reg.
Heatup happens even if the vehicle is not hot and wires connected to solenoid begin to smoke and positive terminal cable to batt overheats.
Any input greatly appreciated.
Old 07-18-2009, 09:00 AM
Poison Oil Racing's Avatar
Poison Oil Racing Poison Oil Racing is offline
Poison Oil Racing is starting off with a positive reputation.
this is probably your problem.
Old 07-18-2009, 10:21 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
At least three should be a braided ground cable on the back of the intake going to the firewall.
Josh
Old 07-18-2009, 10:29 AM
I ran a ground from the block/head where the battery cable ground is, to the frame and it solved all of my problems.
Old 07-19-2009, 02:39 AM
rchawaii's Avatar
Thanks Guys
I will be doing this tomorrow. Just havent gotten my round tuit yet .
Ill repost results as soon as I can.
Old 08-02-2009, 03:16 AM
rchawaii's Avatar
Hiya folks. I added a ground wire as posted above. Unfortunately this has not resolved my issues.
On my 1975 f100 (stock) 2wd) Replaced:
Ign. Module
Coil
Volt. Reg
Solenoid (On the second new one now )
Edit:
Also removed and had starter checked. It checked out just fine.
The thing still overheats the wires on the positive side of the Solenoid. So much so that the last new solenoid I had to knock off the fender well it was overheating so badly!
If anyone could please be so kind as to post a close up pic of their Solenoid Setup, I would be forever greatful. That would be my best option I suppose at this point
Old 08-02-2009, 10:48 AM
byt byt is offline
byt is starting off with a positive reputation.
if I'm understanding this correctly, the cable from the battery to the solenoid and the wires on the same terminal are getting hot?
the cable from the battery brings the current to the terminal but the other leads take current to other things such as the ignition switch and the charging circuit. I would try removing these temp, connect battery cable and see if the lead gets hot, then add one cable at a time to find out which causes the problem. don't forget to insulate the loose leads so they don't short out.
Old 08-02-2009, 10:59 AM
Bullitt390's Avatar
Old 08-04-2009, 12:45 AM
rchawaii's Avatar
Thanks Fellas. It looks like this is all right. Ill be looking at replacing the ign. switch next I suppose. I havent found any shorts unfortunately.
Ths only thing I am not sure of in the pic (Thank you by the way very much) is the black wire with the blue shrink wrap on the ignition pole.
Could a small batter be causing any of this. Mine has like 527 CCA.
Old 08-04-2009, 12:53 AM
Bullitt390's Avatar
The blue shrink wrap wire is my "white" wire from the Duraspark module. My truck was originally equipped with points and I later converted to the Duraspark ignition system.
Some, well most guys attach the "white" wire to the "S" post of the solenoid when doing conversions.
Josh
Old 08-04-2009, 12:58 AM
rchawaii's Avatar
Thanks Bullitt. Is this a difficult and/or expensive conversion and have the plus' been discussed elsewhere?
Thanks again.
Old 08-04-2009, 01:12 AM
Bullitt390's Avatar
Just need a duraspark distributor and module. Price depends on whether you go for the junkyard route or brand new from a parts house.
Possibly around $100 for both new.
Picture of the Motorcraft Duraspark module.
Josh
Old 08-04-2009, 01:15 AM
Bullitt390's Avatar
Not too difficult at all. Just need a module and Duraspark distributor. Depending on what route you go, whether used or new, would determine the cost. Possibly around $100 for all new.
Motorcraft Module
Duraspark wiring scheme
Josh
Old 08-05-2009, 02:32 AM
rchawaii's Avatar
Wierd
Odd, that is the exact ignition module in my truck I'm not sure Im lost on the details or not. I'll try to get more pics this would probably be the most helpful. I can do all the mechanics, electrical is obviously not my forte
Old 08-15-2009, 03:36 AM
rchawaii's Avatar
Well Hi guys. I had a friends friend come over and look at the truck and he said it was wired correctly, aside form the solenoid allegedly "not working correctly" (In his opinion). I purchased another off the shelf solenoid and broke down the other day and went to Autozone and picked up a 772 CCA battery that was $34.00. She started up, no heat whatsoever. I've driven her a little bit and started cleaning her up. Got all the rust on the left fender wll cut out with my grinder/cutoff and applied bondo to that side. I'll likely be removing the original running boards and either leaving off or getting nice chrome aftermarket jobbies.
So, thanks for all of the assistance and insight and ill post updates as I get more done to her.
Next up, carb work!
88 Ford F350 with electrical issues andyofne 1987 - 1996 F150 & Larger F-Series Trucks 24 10-09-2016 03:58 PM
starter problems fordatic 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-23-2016 02:28 PM
Solenoid, starter or ignition?? fyredude 1999 to 2016 Super Duty 15 07-15-2016 02:56 AM
PAINLESS WIRING HARNESS IN 55 F350 mgerdau 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-29-2016 12:17 AM
Correct wiring for ignition, starter, and 4 post relay? TestDepth 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 02-25-2007 06:49 PM
Tags
1979, 2001, 74, 75, battery, bronco, connection, f150, f250, ford, hook, hookups, solenoid, sylinoid, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
