Pre-Bent Stainless Steel Brake Lines - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-17-2009, 10:29 AM
jade97's Avatar
jade97 jade97 is offline
jade97 is starting off with a positive reputation.
With the rusted/busted rear brake line posts here & in the Excusion threads, I contacted some tubing manufacturers to see if they offer Stainless Steel Versions.
Classic Tube (www.ClassicTube.Com) said they have patterns for "1999 F350 4x4 Regular Cab-Long bed & Extended Cab-LongBed" and "2001 F250 4x4 Extended Cab Shortbed".
Can anyone with access to a Ford catalog, see if a Crew Cab Short Bed uses the same lines as either one of these?
Also, is an OE line available from Ford? P/N?
Mine is rusty & I'd like to replace it before it bust's.
Old 07-17-2009, 08:27 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Have you considered just buying the tubing, a bending tool & flaring tool and just making them yourself? Shouldn't be too hard to do.
Brake Stuff for 79 4x4 tjac 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-03-2015 06:35 PM
Steel OEM brake line...can't figure it out iridektm28 2004 - 2008 F150 1 07-31-2014 10:33 PM
1971 parking brake cable 2500ak 1967 - 1972 F-100 & Larger F-Series Trucks 27 03-29-2013 06:03 PM
Stainless Steel brake lines? rpenterics 1999 - 2003 7.3L Power Stroke Diesel 1 09-30-2011 11:06 AM
Stainless Steel Brake lines??? question help? hagerty_justin 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-18-2010 02:51 PM
Tags
350, 99, barke, bent, brake, f350, ford, line, lines, pre, prebent, ss, stainless, steel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
