Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-17-2009, 02:38 AM
63 FALCONSTEIN 63 FALCONSTEIN is offline
63 FALCONSTEIN is starting off with a positive reputation.
8", 8.8 or 9" Differential Swap in a 63 Econoline ?
Looking for some intel on swapping out the weak 6 banger diff on my 63 Econoline. I'll be dropping a 270-285HP 289 in it soon and the OG diff has to go.
I was told a 69-70 Mustang diff will bolt in. Spring perch width and drum width would keep the tires in line like the OG diff. 69-70 Mustang diffs are scarce though.
Anybody done this swap and if so what other model diffs are a bolt in ?
I'd like to swap out the front drums for a disc set as well, using stock components to keep the cost down.
I met a dude years ago that had a 63 Econoline with a rowdy .060 over 289, solid cam, etc. It had a 9" under it and disc brakes up front. He told me he used all OEM parts and everything was a bolt-in deal, but would not elaborate on it. (?)
It was wicked. It rocked and would blaze the tires from a 20 mph roll.
Thanks in advance for whatever info anybody has to offer
  #2 (permalink)
Old 07-25-2009, 09:01 AM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
This will probably be your best bet,much falcon/ranchero info here- http://www.ford-forums.com/ford-falcon/
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
  #3 (permalink)
Old 07-25-2009, 05:37 PM
8', 8.8, 9" Differential swap in a 63 Falcon Econoline
Thanks for the tip. I'll check out the forum and see what I can find.
FALCONSTEIN
  #4 (permalink)
Old 07-28-2009, 12:36 AM
Econousaparts Econousaparts is offline
Econousaparts is starting off with a positive reputation.
Nothing but a stock 61-67 econoline 9 inch is a direct replacement for you. Also no OEM discs I know of are direct bolt on,they all need some mod or machining. D and D Brakes in Oregon makes a nice conversion kit thats all direct bolt on though and theres a few other possibilities too.
Tim in Ky
  #5 (permalink)
Old 07-28-2009, 12:58 AM
8", 8.8, 9" Differential Swap in a 63 Econoline ?
Hey Econo, thanks for the info.. I found a few around but they were in horrible condition from being left out in the elements for decades, not cool . Of the 4 I found none had a 8" or 9" diff. The little 6 banger diff is sturdy, but not enough for a 280-290HP V8.
What's the scoop on a 289 swap. motor mounts, cross member, etc. Also, is there a link to a wiring schematic break down to covert from gen-to-alt ?
Any info will be appreciated. Falconstein
  #6 (permalink)
Old 07-28-2009, 01:22 AM
Wiring diagrams,engine swap info,rear end info and tons more is available at oldeconolines@yahoogroups.com Its been covered there many many timnes over. I ve got 9 inch rear ends if you need one and also can set you up with a v8 crossmember for the swap.
Tim in Ky
  #7 (permalink)
Old 07-29-2009, 07:20 PM
vanishingbreed vanishingbreed is offline
vanishingbreed is starting off with a positive reputation.
why do you want to do a V8 swap?? You can build your stock inline six to have up to 300HP and still get over 20mpg . A lot less mods to do that way although you would still need a good 9".
  #8 (permalink)
Old 07-29-2009, 09:40 PM
Differentail swap in a 63 Econoline
Hey Vanishingbreed
I thought about a beefed up 6 banger but the true cost for that type of build would be more than the 289 swap. Primarily, because I have a donor 67 Ford Custom I bought for $250 to part out.
I built a 250-6 for a buddy of mine in 1979. We put it in a 66 Econoline. It was bored .40, stroker crank (Scat), solid lifter comp cam, holley 500 cfm 2-BBL, custom intake (welded individual runners), etc. It would spin the right tires from a 3rd gear roll. No HP/TQ numbers on the motor but it was really strong.
It was more $$ than he thought. I might not even do the swap if I find a fresh 6 to put in it. I have 7 classic projects right now and the Falcon Econoline runs right now.
Falconstein
  #9 (permalink)
Old 07-29-2009, 09:53 PM
Quote:
Originally Posted by 63 FALCONSTEIN View Post
Hey Vanishingbreed
Falconstein
I swapped a stock 170CI for a 200CI. Built the 200 using Clifford Performance parts for $1400.00. Now have a 200HP motor that gets 26MPG so the savings was not only in the motor but in the amount of gas too.Big difference from 4mpg to 26mpg especially at the cost of gas today. My 66 Econo with the 347 stroker was a wheelstander but could not be driven everyday especially when the temps. got over 100 degrees here and I had a larger custom aluminum radiator in it ($700.00) and a 3200 cfm electric fan. A $12,000.00 motor.
Tags
1961 , 1964 , 1967 , 63 , diff , differential , econoline , econousaparts , end , inch , mustang , ranchero , rear , swap , width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
