air hog vs. K & N
Glad to hear your v-10 is so awesome. back to your ?, if you have mas/maf sensors the oil in oil treated filters can cause your sensors to go bananas. Major problem. My advice is to stick with dry filters. take it or leave it. I will try to help even a gasser if its a Ford.
bill,
Not sure what you're after. If it's a performance gain, I highly doubt you'd ever see much of a difference between the two. If it's a mileage difference you're seeking, then I doubt you'd ever recoup the money spent on the new system. If you're asking if there's a difference between the two filters ablity to filter dirt, it's unlikely anyone here has spent the time and money on the equipment necessary to measure that difference. Though I think bobistheoilguy.com may have done some research in the whole gauze air filter schtick, not sure
Don't know what year your truck is, but I thought the '04 and up V10 flowed all the air needed up to 5000rpm. I have a stock air intake on my '96 wagon, and it flows all the air that stock engine needs up to 5000rpm as well. The air intake systems on most cars and trucks built in the last 10yrs or so do more than an excellent job of pulling cool air from the front of the vehicle and not from the hot engine bay. In fact, I had used a K&N CAI filter on my '93 F150XL w/ the I6. Trueth be told that system actually required me to scrap my factory cold air induction and strap on their filter to my intake duct. At that point I was sucking in the hot air from the engine bay. I ran that K&N CAI for 130,000 miles, I washed the filter and oiled it 4 times in that period. Never had a problem with it, and never noticed any grit in the intake ducting, throttle body, or intake manifold. I stuck a thermocouple inside the K&N filter once and recorded temps up to 145deg F while at idle and crawling thru traffic. But, as the speed increased over 35mph, the engine was soon pulling the much cooler air from outside the truck.
K&N and other CAI setups can offer real performance gains, but only when other engine modifications are factored into the equation. Aside from the increased engine noise I was less than flattered with what the K&N system cost vs what my old '93 F150 got out of it. And as such decided to leave my V10 alone. Others on this site have added CAI kits to their V10s, should only be a matter of time before someone chimes in with their results.
Though as I said, I've seen many a so called CAI system that required you to abandon your very real, very functional factory cold air induction so you could bolt on their kit. Only to have it suck in hot engine bay air.
Bottom line, I'm not sure what you're after to offer a valid response to.
Enjoy,
RustyFuryIII
Enjoy,
RustyFuryIII
I have a 2v V10 that i put a fram air hog on years ago.
Are they as good as K & N or should i buy one of those?
You can stop it now ...
There once was a problem with K&N over-oiling their filters from the factory. It happened around the 1997-1998 time frame, I bought one for my '96 t-bird and it was dripping wet. After they fouled quite a large number of MAFs (leading to the urban myth that all K&N's cause this), they fixed the production issue and there are no more problems.
I now run that same filter in my '97 Cougar, after redoing it myself and there is NO OIL on my MAF when I clean it.
Yes, with a jab or two mixed in. If you want to "help", leave them out
To the original poster:
I ran an Air Hog in my V10 for quite a few years, after going through quite a number of paper filters. Around here (Metro NY), diesel soot clogs up the paper filters and I can tell the difference in only a few thousand miles. With the Air Hog, there was no performance drop-off noticeable, and there was never EVER any dust or other matter inside the air intake tube.
As for which one is better, I don't really know
I do have a Volant CAI now, which helped low-end torque (helped spin the tires from a stop a little better) most likely because it changes the entire intake tube and removed an abrupt almost 90-degree angle right after the air box. However, that was after putting ebay headers on, so I can't say for sure how much it would help a totally stock engine.
It's one of the few setups that replace the entire intake tube and air box and doesn't get hot engine bay air
I've only had 4 personal vehicals since I first got a car 30 years ago. They must last to me, they are not disposable every couple of years.
Ford advises; changing the paper air filter to frequently can cause premature engine wear. Think why
Hows about using an oiled one in place of your in cabin air filter. Yea, you could flow more air thru the vents sweet.
on
[quote=Zedrive;7732518]I've only had 4 personal vehicals since I first got a car 30 years ago. They must last to me, they are not disposable every couple of years.
So you're saying that Ford relies on partially restricted intake air flow to maximize longevity? I don't think so. The only premature wear from changing filters too frequently might be your wallet.
First my appologies. I attributed this to Ford but I can only find it written on All data under Intake air system.
From the back of a K&N filter box.
As dirt builds up on the outside of a K&N filter, it acts as part of the filter media further extending the filters service life.
All filters have inherent to their service life a period of optium filtration It is not at the beginning and it is not at the end.
So to flow for 50,000 miles how big of particals do we start with.
Paper good
Now, for race day
Paper good
Now, for race day
