88 Dana 60 Dually Front Axle - Ford Truck Enthusiasts Forums
Old 07-16-2009, 07:14 PM
69crewcab's Avatar
69crewcab 69crewcab is offline
69crewcab is starting off with a positive reputation.
Group
can an 1988 dana 60 front axle(from a stakebody 4x4 dually truck) be used in a reg F-350 truck?? Or is there something that needs to be converted over to use it with standard wheels??
Old 07-16-2009, 07:33 PM
vman vman is offline
vman is starting off with a positive reputation.
As far as I know,The rotors and lockouts have to be changed.Thats why you can buy dually front ends cheaper.
Old 07-16-2009, 08:17 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
rotors/hubs from a single wheel dana 60 or ttb dana 50 will work I also happen to selling dana 50 hubs/rotors from my old axle
Old 07-16-2009, 08:41 PM
69crewcab's Avatar
steve
how much for the hubs/rotors??
joe
Old 07-16-2009, 08:48 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Quick question here....Is the Dana 60 a solid front axle?? Or like the Dana 44 HD Independent front axle.
Old 07-16-2009, 08:59 PM
69crewcab's Avatar
solid front axle or monotube
Old 07-17-2009, 10:34 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
to convert the dana 60 dual wheel front axle to single wheel application, all you have to do is unbolt the dual wheel spacers from the front hub.
Old 07-17-2009, 11:23 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
^what he said^
Old 07-17-2009, 12:53 PM
pretty sure that is 2wd only. . .else I doubt you would EVER find the cheaper dually dana 60 front for sale when you could spend a few minutes to unbolt spacers and jack the price up a few hundred bucks
Old 07-17-2009, 01:41 PM
Quote:
NO NO NO A D60 from a DRW is EXACTLY the same as a D60 from a SRW except for the dually adapters and lug nuts. Done. NOT MY OPINION>>FACT!!! They are cheaper because many people think just like you, that the rears are different when in fact they are the same. Not bashing you, just stating a proven fact. And trying to clear up the misconception
Old 07-17-2009, 02:26 PM
i ain't rite
it is the 2 wheel drive that has the different hubs. the 4X4 is nothing more than a D60 with the adapters bolted on.
Old 07-17-2009, 05:29 PM
Centurion Conversion using bolt on adapters. I understand that these can be unbolted and is basically a SRW Dana 60 axle. . .
but I have also seen a number of these for sale, and these are the style I'm referring too when people ask about converting (at least those I have talked too). . .
Which have actual Dually hubs. . .
Though, the above pics are from a BJ Dana 60. . .here is a king pin dana 60 with actual dually hubs. . .
Is it a year split somewhere? If so, where? I only know what I see, and those are what I run into. . .I state neither opinion or fact on this one, just what I have found. . .
Original poster, which one looks like what you have? I guess that answer is the direction you need to take in this matter of conversion
Old 07-17-2009, 06:09 PM
Just unbolt the adapter from the rotor. DONE . YOU NOW HAVE A SRW D60.
As for the cut off of the King pins, the last year is 91 of them 92 and newer is BJ
Old 07-17-2009, 06:20 PM
i ain't rite
as you said, this is a Centurian conversion. that did not come from ford like that.
these other pics are the bolt on adapters i was referring to. if you unbolt them and put the long studs in the rotor/hub assembly, you will have a SRW D-60 front axle.
Old 07-17-2009, 07:29 PM
I don't think those are bolt on, they are the actual hub. They are machined inside for press in bearing races and have broached splines for internal hubs. The dually adapter part is actually cast into the front of the hub. the rear part has cast and drilled ears for a rotor to bolt onto. . .If they are like the GM dually hubs it is questionable whether you should support vehicle weight on them
If I'm wrong, let me know. . .I'm humble
96 f350 2wd to 4wd TTB or 05 or newer solid front axle ranger_ 1987 - 1996 F150 & Larger F-Series Trucks 33 10-19-2016 10:04 PM
68 Napco conversion Broncodawg 1967 - 1972 F-100 & Larger F-Series Trucks 14 03-03-2016 09:52 PM
4x4 Dually Kirbys73F100 1973 - 1979 F-100 & Larger F-Series Trucks 103 08-15-2013 06:04 PM
Dually Dana 60 for regular rims? PowerStroker94 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-18-2011 09:24 AM
Dually conversion PowerStroker94 1994.5 - 1997 7.3L Power Stroke Diesel 13 09-30-2011 09:57 AM
Tags
1990, 60, axle, conversion, dana, dually, f250, for, ford, front, hub, hubs, sale, single, spacers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
