4.9 Blow By
Old 12-13-2010, 03:02 PM
Tater50's Avatar
Tater50
Tater50 is offline
4.9 Blow By
Help: sounds serious; looking to buy a 95 F 150 4.9; Auto 4x2; blows oil thru breather
Thanks
Later/Tater
Old 12-13-2010, 03:40 PM
nstueve's Avatar
nstueve
nstueve is offline
i'm guessing you are talking about a valve cover breather??? if you are blowing oil out the valve cover you are looking at having a couple bigger problems that aren't fun to deal with...
Old 12-13-2010, 04:02 PM
rikard's Avatar
rikard
rikard is offline
It could be anything from a bad PCV valve to broken rings or pistons. Most 4.9s seem to stay pretty tight until 250k with basic care. If your serious about the truck do a compression check to check the health of the cylinders.
regards
rikard
Old 12-13-2010, 05:08 PM
Tater50's Avatar
Tater50
Tater50 is offline
Reocurring Senior Moment
They come too ofter: oil blowing back into the air intake filter
Later/Tater
Old 12-14-2010, 08:25 AM
nstueve's Avatar
nstueve
nstueve is offline
like suggested above. Get a $20 compression tester and check the compression in each cylinder. I usually squirt a little oil in to seal the side wall. if you have bad rings or a broke piston it oil won't make a difference. If it were me... I would want 100psi minimum in each cylinder, and no more than a 10% difference between each cylinder.
Old 12-14-2010, 08:35 PM
mr_malina's Avatar
mr_malina
mr_malina is offline
I had the same problem in my truck for years, finally gave in and bought a new engine vs tearing mine apart.
Old 12-14-2010, 11:31 PM
dmclane's Avatar
dmclane
dmclane is offline
Thanks
Later/Tater
from personal experience i have had two start giving me the same trouble and both are dead now it is very wise to do as he had said (check the compression first) if i had done that maybe my engines would still be going
Old 12-15-2010, 11:48 AM
Dan92's Avatar
Dan92
Dan92 is offline
if you have your engine running and you pull the valve cover breather tube out of the side of the air filter box is there smoke coming out also?
Old 12-15-2010, 12:37 PM
mr_malina's Avatar
mr_malina
Mine did........................
Old 12-15-2010, 01:20 PM
Dan92's Avatar
Dan92
Dan92 is offline
mine was doing that and after tearing out my engine and taking the head off i could see and feel a scratch on the wall of a couple of my cylinders. therefore, i had a couple cracked rings and paid to have my engine rebuilt. blow by with smoke is almost always a cracked piston ring
Old 12-15-2010, 01:47 PM
mr_malina's Avatar
mr_malina
That was my assumption too. I got a reman motor with warranty for cheap to replace. This sounds like a common problem.
Old 12-17-2010, 05:07 PM
Dan92's Avatar
Dan92
Dan92 is offline
yeah, it happends here and there. i had mine totally redone, (new cam, pistons, timing chain and everything) all for $2100 thats including having the head rebuilt also.
Old 12-20-2010, 03:00 PM
nstueve's Avatar
nstueve
nstueve is offline
The last one I had with blow by... the 83 red one below... My FIL thougth it was just a litle "slack in the cylinder" and that it was ok... I told him not to run it... What did he do??? Drove it the next day to the feed store. Shattered the piston skirt and put 4 cracks in the side wall of the #3 cylinder. I'd have to sleeve the cylinder to save the block... In other words it's now a JUNK BLOCK. I really wouldn't by a motor with blow by unless the truck has zero other problems and is really cheap. Blow by is just a ticking time bomb...
tater p/s
07-30-2015 10:34 AM
tater_51
26
07-26-2011 11:11 AM
Tater50
87
02-06-2011 02:40 PM
tater_51
01-15-2010 12:41 PM
Taters
01-01-2010 11:26 PM
Quick Reply: 4.9 Blow By
