Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-15-2009, 09:22 PM
johaner78 johaner78 is offline
johaner78 is starting off with a positive reputation.
interior paint codes for 1978
Trying to find out the correct color to use on my 1978 F250 4x4 Crew interior (dash, glove box door and ashtray door). The exterior codes for my truck are AV (Gloss Black and Med. Silver Metallic). It has the racetrack trim. The dash for this truck was not Gloss Black, instead more of a dark grey to black color. In searching the internet, I came across the 1978 Ford interior color codes. It lists a Black (Ditzler code=9255) and Black Poly (Ditzler code=32585). Both colors are listed as "Semi-gloss". Question i'm wrestling with is this: should I paint the interiour the Gloss Black the same as the exteriour or paint it the dark grey to black color that the dash was painted (hopefully it's one of the codes listed above). Do most people paint all the interior the same color as the exterior or do most people follow the "interior paint codes"? Thanks for your input!
__________________
1996 F150 4x4, 351, auto, LB, K&N Filtercharger, "Silver Bullet"
1978 F250 CC, sb, 4x4 "in the works"
  #2 (permalink)
Old 07-15-2009, 09:29 PM
ranger429 ranger429 is online now
ranger429 has a good reputation on FTE. ranger429 has a good reputation on FTE.
I just painted the dash for my crewcab. I did it the same color as the truck is going to be but in your case a gloss black dash is going to be to much black. I know someone else who did there dash black with an all black truck and it is just to much black. What is the color of the rest of the inside of your truck?
Here is a picture of my dash after paint. With a black dash pad and black door panels it should compliment it good.
With some of the stuff added on, waiting on the glovebox woodgrain.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
____________79 F-250 4x4 Crewcab, under the knife____________
  #3 (permalink)
Old 07-15-2009, 09:49 PM
Ranger429 - the color you used on your dash is really da_ _ close to the original color of my dash. What brand of paint or paint code did you use? The rest of the interior is Black dash pad, black door panels, and the original cardboard headliner was an off white (kinda like a cream color...uuggh) but will probably try to find a headliner color to match the exterior Med. Silver Metallic. I really like your dash especially with that black pad on there!!
__________________
  #4 (permalink)
Old 07-15-2009, 09:58 PM
Yeah if you have an all black truck and interior the charcoal would look good in there. It is an 82 Chrysler color code AA9 color. I had the cream headliner as well, all brown truck, so I am going to get a custom one done at the upholstery shop.
The Bronco still has the stock dash color, probably what you had.
__________________
  #5 (permalink)
Old 07-16-2009, 09:27 PM
Ranger, yea that Bronco dash is the same color as my 78 Crew dash was. Thanks for the code that you used - it looks pretty darn close to the original factory color. Why did you use a Chrysler code??? Did you not know the original paint code for the interiour or they didn't match? THere are a couple codes for the '78 interiors for the trucks. I dont' know which one to pick....
__________________
  #6 (permalink)
Old 07-16-2009, 09:33 PM
I didn't even look for the original code. The crew I'm restoring is all brown (yuck!) and I'm changing the whole thing over to the same gray that I did the dash in. I could probably look thru my color book and see if I could find the original dash color.
The color I used above is from an 82 Chrysler and the color code is AA9. Any paint supply store can cross that into their brand of paint.
Oh wait you asked why? It was the nicest looking gray that I found in my color book.
__________________
  #7 (permalink)
Old 07-16-2009, 09:36 PM
76f350spercamprspeal's Avatar
76f350spercamprspeal 76f350spercamprspeal is offline
~<>~"76SCS"~<>~
1976 Ford F-350
My Garage
76f350spercamprspeal has a great reputation on FTE. 76f350spercamprspeal has a great reputation on FTE. 76f350spercamprspeal has a great reputation on FTE. 76f350spercamprspeal has a great reputation on FTE.
Actual Color may differ from Shown color.
__________________
Thanks, -76SCS--Anthony-
"IRS: We got what it takes to take what you got!" "If you survived the '60s and/or the '70s, you can survive any damn thing!"
Click here to Vote in Round-3 of the '61-'79 Classic Championships!
Click here for Links To All The Championships!
Last edited by 76f350spercamprspeal; 07-16-2009 at 09:45 PM. Reason: Added Interior Codes.
  #8 (permalink)
Old 07-16-2009, 09:39 PM
Those are all exterior colors.
__________________
  #9 (permalink)
Old 07-16-2009, 09:57 PM
Here is the correct color chart. The color you want is in the 1st row on the left, 2nd one down. Black metallic color code A4A. Dupont # is 9354. The color chart above does not even list a black metallic.
My scanner does the color chip no justice, it is identical to the color in the dash of my Bronco.
Full size image: http://www.supermotors.net/registry/media/744126_1
__________________
  #10 (permalink)
Old 07-16-2009, 09:58 PM
76SCS - thanks but I've already found that information.
Ranger - would the top of the dash (the metal part under the windshield be the same grey color as the front side of the dash or would it be the same gloss black as the exterior color?
__________________
  #11 (permalink)
Old 07-16-2009, 10:02 PM
No, it is the same as the front of the dash originally.
__________________
Tags
1978 , black , chips , codes , color , colors , dash , f100 , f150 , ford , fordtrucks , interior , original , paint , pictures , ranger , silver , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
