PCM fuse blowing on 2003 6.0 L Diesel
2003 Ford F-350 Superduty with 6.0L PSD 4x4 - 120,000 miles with no major issues so far.
Last week I was driving at highway speed and the engine just shut down and would not crank again (all electrics appeared to work except for the starting circuit). I took it to the dealer and they found that the fuse for the PCM was blown. Replaced fuse, test drove and let run in shop all day finally blew fuse as I was there to pick it up. let it cool down and put a new fuse in an ran fine for another day or so then shut down again. Went through 4 other fuses (fuse blew as soon as ignition was switched on) and then let cool down another 20 or so minutes and then started ok and made it to my destination. Has anyone else had experience with the fuse for the pcm blowing. I will try to see if I can get codes off of it later this week since the dealer seemed not to know where to start troubleshooting. I am assuming that my pcm may be going bad, since It works fine when it cools down.
Also had a strange gremlin hit in the ac system- when I switch from 2x4 to 4x4 the ac changes from blowing out the dash vent to the defroster. Not sure if this is related.
Thanks in advance
TC
Thanks in advance
TC
Per the wiring diagram that wire runs from the central fuse junction box to the ignition switch. Assuming you don't have a remote start I would check the wiring to the ignition switch. Other than that you might suspect the FICM since it also powers the FICM in the run position and the FICM uses alot of power.
This sounds freakishly similar to what is happening to me right now....
https://www.ford-trucks.com/forums/8...me-please.html
I'm going to check my fuse right now.......
compucarnut
16
09-23-2016 08:42 AM
Michael Warnick
06-06-2016 11:59 AM
