'50 Power Brake Conversion
Old 07-15-2009, 10:35 AM
Woodsman_30350's Avatar
Woodsman_30350
Woodsman_30350 is offline
I have a brake problem on my 1950 F-1. The setup has a TCI IFS front suspension with disc brakes and a Ford 8" rear end with drum brakes from a '68 Mustang. I have a CPP conversion with a master cylinder, brake booster and proportioning valve installed.
The brakes have good stopping power. When stopped, the brake pedal returns quickly when depressed however when moving the brake pedal tends to return very slowly causing the bakes to drag. If I return the pedal manually, all works fine. I called CPP and they said that some installation need a pedal return spring. Does this make sense.
Old 07-15-2009, 01:36 PM
Old F1's Avatar
Old F1
Old F1 is offline
If it is floor mounted, then a return spring would sound possible.
Old 07-15-2009, 03:12 PM
gearhead1952's Avatar
gearhead1952
gearhead1952 is offline
I would go with a return spring also. Keeps the weight of the pedal off the master cylinder pushrod and speedy returns. Could probably use the stock return spring.
Old 07-15-2009, 11:11 PM
wmjoe1953's Avatar
wmjoe1953
wmjoe1953 is offline
We installed an aftermarket kit in a '37 Chrysler. The kit required a return spring. Install one, and you're good to go.
Old 07-16-2009, 10:14 AM
Woodsman_30350
Yup! That did it. Thanks to all for the input..
Old 07-16-2009, 10:20 AM
DROPTOP46's Avatar
DROPTOP46
DROPTOP46 is offline
At No Limit, we make P/B kits for many trucks, and yes, many do need a return spring. 55-59 chevs had them stock. Slow return is common, especially with low vacuum, or tight fitting carpet.
I once was fortunate to have lunch with a guy who built F-100's at the factory. "When we built these", he told me, "They we're little more than 'Tractors with Windows', now, you guy's are trying to make them into Cadilacs". I always try to remember that.
Have a great day!
carnut122
27
09-16-2015 09:36 PM
natewatts5
07-22-2015 03:34 PM
zombiefied 247
06-02-2015 10:45 PM
Jules The Great
02-18-2015 08:49 PM
ohbrian
17
03-16-2014 11:23 AM
Quick Reply: '50 Power Brake Conversion
