Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-15-2009, 08:57 AM
F-250 restorer F-250 restorer is offline
F-250 restorer is starting off with a positive reputation.
Offy heating plate
Hey guys--
I live in S. California. Do I need to connect my cooling/heating lines beneath my Offy DP manifold? I am running headers.
  #2 (permalink)
Old 07-15-2009, 12:41 PM
Kuskoal Kuskoal is offline
Kuskoal is starting off with a positive reputation.
it would be a good idea, even if you see 80*+ weather like me in nevada.
  #3 (permalink)
Old 07-15-2009, 10:39 PM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
http://i144.photobucket.com/albums/r...Picture035.jpg
http://i144.photobucket.com/albums/r...Picture027.jpg
http://i144.photobucket.com/albums/r...Picture026.jpg
Use 3/8-1/2 aluminum plate. A bit nicer job can be done using brass fittings rather than pipe fittings.
Running the water heat/coolant provides for better atomization and stabilizes temperatures in the induction system regardless of the weather.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #4 (permalink)
Old 07-16-2009, 01:41 AM
rikard rikard is offline
rikard is starting off with a positive reputation.
I prefer the hot air system myself. Years ago I put on an after market header and intake eliminating the heat riser on a old AMC 258 I used a temperature controlled air cleaner to feed 80 deg air to the carb. Had no issues and I live in New England.
One of the mods that the GM LT1 boys like to do is to bypass the coolant to the TB to lower intake temps.
regards
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #5 (permalink)
Old 07-16-2009, 02:43 PM
Either way the idea is to stabilize the intake temperature which carbs especially like. Easier to tune when reducing the temp variable.
__________________
  #6 (permalink)
Old 07-16-2009, 03:51 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a good reputation on FTE. Col Flashman has a good reputation on FTE.
'Old Man' Johnson of JMS Racing Engines drilled & tapped my Offenhauser 'C' Intake & connected it to my radiator system to provide heat.
Works real well too.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #7 (permalink)
Old 07-17-2009, 02:25 PM
Ranger GT2's Avatar
Ranger GT2 Ranger GT2 is offline
Ranger GT2 is starting off with a positive reputation.
Will the plate fit if your using headers instead of the original split manifold?
__________________
1982 F100 300 six 4 speed O/D 2wd
  #8 (permalink)
Old 07-17-2009, 06:07 PM
The only way it does not fit is with the stock log exhaust manifold.
__________________
  #9 (permalink)
Old 07-17-2009, 07:37 PM
Ranger GT2's Avatar
Harte3 did you use the dark ford blue on your engine? I'm painting mine and the color you used looks good.
__________________
  #10 (permalink)
Old 07-18-2009, 12:48 PM
My engine builder painted it...close enough to Ford blue for me.
__________________
  #11 (permalink)
Old 07-31-2009, 10:22 PM
Goatzilla Goatzilla is offline
Goatzilla is starting off with a positive reputation.
Quote:
A question - does the Offenhauser intake have a small chamber molded in at the base that the warm coolant collects in?
  #12 (permalink)
Old 07-31-2009, 10:27 PM
Yes, but it does not come with the plate and fittings to connect your heater lines to it. You have to make it yourself. Harte3 posted photos of the one he made for it.
  #13 (permalink)
Old 07-31-2009, 11:14 PM
Yeah, i figured that much out.
Just didn't know if the fittings on his plate terminated at the outside of the intake and just conducted heat through contact with the intake or if the intake actually had an uncapped 'resevoir' you could pump coolant into.
Thanks for the reply.
  #14 (permalink)
Old 08-01-2009, 02:43 AM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
How is it sealed? Is it just RTV around the edges?
  #15 (permalink)
Old 08-01-2009, 10:59 AM
Yes but one could also make a gasket like what is used on a thermostat housing.
__________________
Tags
200 , 300 , 49 , exhaust , ford , header , heat , housing , intake , l6 , offenhauser , plate , riser , thermostat , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
