Need to know about hose from oil valve cover to airbox
Old 07-14-2009, 09:58 PM
Ford Super Duty Man's Avatar
Ford Super Duty Man
Ford Super Duty Man is offline
I have a1990 F350 with 460 and would like to know the function of the hose going from the neck of where the oil goes to the airbox. when replacing the air filter I noticed a little oil in my airbox. Is this normal or do I need to replace anything??
Old 07-15-2009, 12:54 AM
andym's Avatar
andym
andym is offline
A little oil is normal. It's part of the crankcase ventilation system, the vapors get sucked into the intake and burned as opposed to letting them escape into the air.
Old 07-15-2009, 01:46 AM
StealthWyvern's Avatar
StealthWyvern
StealthWyvern is offline
Install a oil catch can if your worried about the vapors
Old 07-15-2009, 04:28 AM
jr32560's Avatar
jr32560
jr32560 is offline
check/change the pcv valve-that hose should be the filtered air going into the motor -probably on the drivers side vavle cover right? the pcv valve is on the opposite one-as the motor pulls air in from the pcv valve it needs to pull air from that pipe-should be a special little air filter for it also -well there is on the smaller motors
Old 07-15-2009, 06:33 AM
Ford Super Duty Man
Ok guys, thanks for that info !!
Old 07-15-2009, 09:22 AM
jas88's Avatar
jas88
jas88 is offline
Also be sure to check to make sure you have vacuum on the hose going to the PCV. I have seen more than once the vacuum port coming off the intake plugged up with carbon.
KIDkiser
06-21-2011 08:27 AM
BRay09
01-21-2011 07:25 AM
Uncle Grumpy
12-13-2009 06:04 PM
EhBrah
10-25-2009 07:01 PM
vols_fan22
15
03-09-2007 03:49 PM
Quick Reply: Need to know about hose from oil valve cover to airbox
