How hard is it to replace an A/C Compressor clutch? - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 07-14-2009, 08:56 PM
desertranger desertranger is offline
desertranger is starting off with a positive reputation.
I have 148,000 on my 2001 Escape and the A/C Compressor clutch is noisy, rusty and appears to be slipping above 2000 rpm. Can it be replaced with normal tools or should it be taken to A/C repair shop?
Just got back from a 4,000 mile trip and it worked till the last 150 miles.
Thanks for your help
Old 07-14-2009, 09:36 PM
StephonGarnett StephonGarnett is offline
StephonGarnett is starting off with a positive reputation.
Hi there! I think you should go to the A/C repair shop nearest to you. Yes it is just a small problem but if you fix it by yourself, you may encounter bigger problems i the future.
_________________
Stephon G.
Old 07-14-2009, 10:01 PM
hilgerbeast's Avatar
hilgerbeast hilgerbeast is offline
hilgerbeast is starting off with a positive reputation.
I just helped my dad replace the whole a/c compressor in my grandma's 01 escape. I don't really know about working on just the clutch assembly, but removing and installing a reman one was super easy. Took us about 20 minutes. You have to remove the lower skirt/mud plate directly below the passenger headlight. The unit is right there: 2 or 3 bolts to remove it and one to remove the lines. just make sure you get new o-rings and maybe even oil them a little when installing. Charging the system should be left to an a/c guy, if you don't have the gauges/equipment. Hope this helps.
___________________________
1986 F250 XLT Lariat 4X4, 6.9l IDI diesel, C6, 33's on alum mags, huge "bambi basher"
Old 07-15-2009, 06:31 PM
Ended up taking the Escape in and the shop pointed out the drive end of the AC Compressor was leaking. The Clutch was well worn so both the Clutch and Compressor where replaced.
Thanks for your input.
92 F250 A/C compressor clicking noise tomluoma Cooling, Heating, Ventilation & A/C 0 09-04-2012 03:25 PM
93 Ranger A/C clutch or compressor bad? 1998Ranger25L153CID Ranger & B-Series 2 02-11-2010 06:41 PM
A/C Compressor Clutch Clearance IronMiner 1997 - 2003 F150 7 02-18-2007 12:54 PM
need help with A/C young-g-ma Cooling, Heating, Ventilation & A/C 3 06-17-2005 08:13 PM
a/c compressor clutch smitty7 Cooling, Heating, Ventilation & A/C 4 10-21-2003 03:18 PM
Tags
2006, 98, ac, change, clutch, compressor, escape, f150, ford, hours, remove, removing, repair, replace, replacing, shop, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
