Rear view mirror gauge pods
I want to add 3 more gauges to complement my 4 screen Quadzilla standalone I use.
Has anyone ever used the gauge pods that mount in the headliner above the rearview mirror?
How does it mount?
Is it secure or can I expect it to fall off in a month?
I can only assume the tabs slip into the headliner and the back portion utilizes velcro tape to hold it steady.....
If anyone can elaborate I would appreciate it.
Thanks
Joe
How does it mount?
Thanks
Joe
Excellent.
jmaskew,
That is what I was worried about, is the adhesive coming off in high heat...I frequent AZ and not to mention the heat in SoCal can hit 110* at times. Where did you get yours from? I just looked at your gauge pod...it looks very nice. It looks like you were able to conceal the wiring in the headliner nicely.
Thanks for the replies guys!
jmaskew,
The scangauge II have a very nice mount to install the scangauge on the rearview mirror. I bet that you could adapt that mount to secure your pod from the bottom. Check the pictures on their site to see if it fit your needs.
I have the scangauge with that mount. If you need any pictures from diff angles or measurements let me know........
Here's the link www.scangauge.com
And a pic from an auction
http://pic90.picturetrail.com/VOL219.../369632290.jpg
Do a search on this site that's how a find it. A couple of folks have it over here....
Not the best of gauges, but it's better than nothing
I installed the 3 gauge pod over my mirror and love it. It was a pain to install though since the velcro would not hold and even 3M double sided tape did not keep it in place. I used clear silicone and ran a bead around the edge of the pod to help secure it to the windshield. It has been in place for over 3 years now and I would not do it any other way. One other bit of advice, if you are installing a boost gauge spend the money and get copper tubing. Just my 2 cents and the best thing I did for the install.
Excellent.
jmaskew,
jmaskew,
I got mine from Diesel Manor too. I'm very happy with it and it has stuck fine the two years I have had it up. I wiped the winshield with alcohol before I put it up and warmed the spot with a hairdryer. Since I already had a bunch of gauge hardware for my prior gauges on the driver side. I ran the wires up the passenger side. I put all them little gauge boxes behind the glove compartment.
Waltdog
22
12-16-2010 10:10 AM
lakerats
10-14-2010 10:21 PM
