SD caliper slide pin upgrade question?
I'm replacing my front brakes and apparently the calipers call for a new
type of slide pin. I noticed these new slide pins have one pin with a rubber
grommet on the end and when installed it doesn't move in and out easily
like the old style pins. I heard these new pins were to fix a premature corrosion problem. Anyone work with these pins? Any thoughts?
Thanks.
Thanks.
I installed new slide pins in mine a while back. I accidentally slid the pin with the rubber piece into the bore, as a quick test fit, without grease on it and it was REAL tight. Both pins need a good coat of high temp caliper grease on them to move properly.
Some pics of mine here....
http://www.frontiernet.net/~jmray/F250CaliperPins.htm
Yeah, if you greased them you should be ok. Mine fit pretty snug but I could move them without much effort.
When you first installed them, with grease, did you slide them in and out a few times, while twisting them? That seemed to distribute the grease around a little better on mine. Also, I spread a little grease down in the bores before installing the pins (well, after the first initial test fit failure lol)
I haven't gotten the upgraded pins yet, but the last time I did my brakes one of my pins was frozen in the bore (my truck was pulling horribly to the right when I stepped on the brakes). Took me over an hour to get it out without damaging it (took LOTS of PB Blaster and elbow grease). Next time I dive into th brakes, you can bet I'm going to put in the new pins!
Check out this write-up:
http://www.guzzle7pt3.com/cu.php
real easy and the one with the grommet slides more difficult. I guess I'm expecting it to slide easier. Thanks for the help!
I just did my rear brakes on my 06' F-350,,,RR was squeaking when stopping,,,after getting the bleeder screws loose and working(with heat,, collapsing the 2 pistons,,,installing the new pads,,,and re-attaching,,,the next day the piston was frooze,,slider pins nice and free and greased,,brakes were smoking HOT !!
So out of the 2 rear calipers,,I had to replace one or 50% of them,,,and do the job over,,,the rebuilt caliper was $66 from carquest with the core,,,new slider pins are on it,,,greased and ready to go!!
Now I am going to do my front brakes soon,,,both front wheels are very warm,,,like brakes are dragging some,,,I am thinking to avoid the hassle of doing the Job over again,,(from a froze piston or what ever)I am just going to repalce the front caliper's also,, along with the new pads. truck has 46 k miles on it,, here in CT,,,plowing snow and driving in that stuff takes it toll,,,Here it is 10/18/09,,and big snow flakes are coming down now!
ProStreetDriver
General Automotive Discussion
05-14-2016 12:31 AM
Jesser02EX
04-23-2016 08:50 PM
truckfella
Modular V10 (6.8l)
03-31-2016 10:44 AM
Jim59
1999 to 2016 Super Duty
10-26-2006 04:55 PM
