Computer Chips & Tuners
Bully Dog and 2000 7.3
Old 12-09-2015, 11:56 PM
gvagolf's Avatar
gvagolf
gvagolf is offline
Hi
I have a 2000 Ford Excursion with the 7.3 Powerstroke. I recently purchased a Bully Dog programmer and installed the performance program. I should note that the Bully Dog techs performed a firmware update on my device so it has the latests programs. After installation I receive an intermittent check engine light under moderate to heavy acceleration. Additionally, I get fairly heavy black smoke when accelerating in third and fourth gear. I should also note that I had larger wheels and tires (about 3" more in diameter than stock) installed at the same time.
The error codes I am getting are P1249 (waste gate fail) and P1000 (OBD-II Monitor testing incomplete).
My questions are I never had any issue with the waste gate prior to installing the program. How can I test the waste gate to see if I cooked it under acceleration with the program installed or if there is some other issue causing this error code?
My second question is regarding the speedometer and the shift points for the program / transmission. Are the shift points controlled by the perceived speed by the computer? The car feels like it is shifting early and I have recently installed larger wheels tires and have not yet had the speedometer adjusted.
Thank you so much for taking the time to help me out. I appreciate it.
duckslayer7.3
1999 to 2016 Super Duty
08-07-2019 08:17 PM
aero993
04-16-2018 02:41 PM
cubangt
2009 - 2014 F150
16
01-28-2014 10:44 PM
dmanshane
07-06-2013 08:42 PM
Stang5lgt
03-29-2010 06:22 PM
Quick Reply: Bully Dog and 2000 7.3
