air in fuel line
air in fuel line
I Have a 1999 F250 with a 7.3 diesel and it is idling rough or at low rpm's.I cant run a hose off the valve on back of the fuel filter when idling and there are air bubbles in fuel.Someone mention to me that the injector pump may have a crack in it.Any ideas on troubleshooting will be appreciated.
Stupid question but is your fuel tank full? You have a frame mounted fuel pump and a sending unit with a pickup. Everything else is metal lines, a crack should reveal itself as a damp line or a full out leak. Inspect the metal lines all the way back to the tank. The other option is the sending unit pick up has come off. You will have to drop the tank to inspect it.
If you go into the tank you might consider this mod
http://www.guzzle7pt3.com/hutch.php
http://community.webshots.com/album/32303501JuYKPH
the second link shows just how much air the return line feeds into the tank
Use fuel rated line...
The popular kit is the ITP kit, which is the one I used. Very nice and worth the $$$. Here's a link:
http://www.itpdiesel.com/store.php/products/73L_TankKit
Last weeks kit i just got , had Braided black hose with Black liner inside it.. Even cooler stuff. I am jealous my truck don't have this new stuff..
vls
01-01-2012 06:52 PM
