broken exhaust manifold bolts
Passenger side 360 exhaust manifold 2 front bolts broken off. I recently noticed that the manifold gasket is going bad and while looking at it, I noticed that the two front bolt heads are snapped off. Any suggestions about getting these out? Looks like just the heads of the bolts are busted and not down to the actual head itself. I really don't want to remove the head and have them tapped out if I can avoid it.
I sure.... DIDNT!!!! I ended up snapping 3 of them. Long story short, I had to unbolt the motor mount and lift one side of the motor up to gain enough angle clearance to drill out and tap the holes again. It wasn't all that bad being I used a brand new drill and tap bit with about a 1/2 can of PB Blaster to lube up both bits to get the job done.
To let you know, I even used a torch to heat the bolts up, soaked with PB and went extra slow and still ended up snapping them off.
Sounds like you had a lot of fun doing that. I did hear from someone that mentioned that they never had a problem breaking exhaust manifold bolts on old engines when they used an impact wrench with heat. The person stated that they felt that the reason was all the vibration caused the bolt to let go. I wish I knew before I started taking of mine.
Thanks for the info
Thanks for the info
I have an exhaust leak on the driverside head (71 F250 w/390), tried loosening the first upper manifold bolt, snap! Soaked the other 3 upper bolts in penetrating fluid, run the engine till the heads were nice n hot, snapped off no. 2 after I thought it was actuclly coming loose. Oh well, looks like i am pulling the head off to try to salvage it, and get the rest of the bolts out somehow. If not, guess I am gonna buy another rebuilt head and put it all back together.
I second the impact!! A wrench aplies a side load that snaps the bolt. I know for a fact that you can't aply 400ft/lbs to a bolt with a wrench but can with my impact. I broke one bolt right off when I tried a wrench and had no problems when I pulled the impact out. Just had to undo the motor mounts and tip it to the side while I worked on it.
I still need to pull the head to get the broken bolts out, seems it will be much easier than trying to drill them out with no clearance in the engine bay. Shoot I might even pull both heads, clean them up, ditch the stock manifolds and and throw some headers on it while it's all a part...
garys 68
12-19-2016 01:42 AM
hav24wheel
46
09-10-2015 03:33 PM
tim37
12-30-2014 06:35 PM
jimkari
1997-2006 Expedition & Navigator
02-06-2013 09:39 AM
vlietracer64
04-01-2010 11:21 AM
