Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-21-2001, 12:01 AM
beratte is starting off with a positive reputation.
C6 with a 205 to 203
Does anyone know if a 77 F-150 4x4 with a C6 mated to a NP205 will bolt up to a NP203? Thanks
__________________
Best of luck, Ben
95 Bronco XLT, 302, E4OD, 31" BFG AT's
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-21-2001, 09:56 PM
billyb is starting off with a positive reputation.
stick with the 205. it is a MUCH better unit.
  #3 (permalink)
Old 02-22-2001, 03:28 PM
Yea, I've always heard that the 205 is stouter. I actually have a 203 and am looking at buying a used/rebuilt C6 that was mated to a 205 and am trying to figure out if the transmission will fit. Two things that I like about the 203 is that it has a 2 low and it has a lower low range ratio, so I think I'll keep my 203 for now.
__________________
Best of luck, Ben
  #4 (permalink)
Old 02-22-2001, 05:37 PM
where are you located, i might want to get that 205?
  #5 (permalink)
Old 02-22-2001, 05:43 PM
I don't actually have it yet, I'm debating buying it.
__________________
Best of luck, Ben
  #6 (permalink)
Old 02-26-2001, 10:52 AM
mj mj is offline
mj is starting off with a positive reputation.
does the ford 203 have a different low than every other 203? dodge and chev have about 2.00:1 which differs only slightly from the 205s 1.96:1. so the '203 has a better low range' is not that relavent. if you want to be able to have 2low while the hubs are locked in on a 205 you just need to modify the linkage so that each shift rail has its own lever, i have never been fussy about 2 low if i want low i dont mind if the front driveshaft spins. but if you curently have a c6 203 you should buck up and do the doubler thing from ORD to it.
  #7 (permalink)
Old 02-26-2001, 11:19 AM
I thought the 203 had a 2.72 to 1, I'll have to double check. I hear you on the ORD doubler, all it takes is money, haha. Thanks
__________________
Best of luck, Ben
  #8 (permalink)
Old 02-26-2001, 02:10 PM
Eddie is starting off with a positive reputation.
I'm with you...If I had a 203 core right now, I'd do a Doubler!
Eddie
  #9 (permalink)
Old 02-26-2001, 08:05 PM
91f1502wd is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
