'60 f100
'60 f100
My dad gave me his '60 F100 a few months ago, so I decided to restore it and get things back to original. It has the original 292 engine in it but a 4-speed transmission and rear end out of an F6. Dad tore up the 3 speed back in the early 70's so he just replaced it with the 4 speed since his brother already had that and since it was free. I want to go back to the original but am unsure about a few things. I had a friend give me a '57 F100 with a straight 6. I am going to take the 3 speed transmission out of it, but I know that I am going to run into some problems with the bell housing not matching. If anyone has any info on what I need to do, then it would be much appreciated. Also, I believe the '57 has a different clutch system in it. I think that 60 was the first year to have a hydraulic cluth. I would like to also make the swap with the rear end. I don't think I will have any issues there. It looks like an easy swap. Once I get the transmission and rear end issues taking care of, I am going to rebuild the engine. The engine hasn't ever been rebuilt so it definitely needs it. I am not sure how many miles it has on it, since the speedometer linkage didn't hook up to the 4 speed tranny. It had set up for over ten years this last time. I rebuilt the carb, put new points and condensor in it and it fired right up. I would love to get any input on this rebuild process from the engine to the rear end if anyone else has had similar experience. I will take some pics and post them soon. Thanks in advance for any input or suggestions.
Brandon
Brandon
The 57-60 had hydraulic clutch and here is a good place to figure out your vin
http://www.mercurypickup.com/1960vin.htm
The 3-speed uses a different bellhousing to the 4-speeds. You'll also need the column shift stuff, unless you install a stick-shift conversion (I think Hurst/Indy still makes those). But, I also can't see much reason to go from a working 4 speed back to the 3 speed. It'd be better to install a rear end with a different ratio, like a 3.00 which would make 4th seem like overdrive for highway use. The 4-speeds are much tougher, and the granny 1st gear will be welcome if you ever haul heavy loads or drive steep terrain.
I still have the the column shifter on my steering column. Whatever other linkage I need, I should be able to get off of the '57. I am thinking more about what your saying about the 4 speed. I was just thinking about the way it looks. I figured it would look better with the "original" 3 speed. Do you not think so?
Don't make extra work for yourself...if you're happy with the performance of the 292 and four speed, keep it. Good luck.
Well, if you were going to build a restored show truck with the intent of winning trophies, then original is better, otherwise, what you have will probably go unnoticed. But then again, if you were building a restored show truck with the intent of winning trophies, you wouldn't be starting with a '60! We're still the ******* stepchild of the F series line!
the '58 vin you have is
f10=f100
j=223ci 6 Cyl 1BC Carb
8=1958
k=Kansas City, MO build city
the rest is the serial number.
Good for you, I love the '58. If you are going to use it as a parts truck let me know I have some parts I am looking for that you might not be using. Send me a PM.
Regards
Cbass
f10=f100
8=1958
Regards
Cbass
Jetcopterpilot
31
03-28-2013 10:58 PM
1976fordguy
12-18-2012 07:21 PM
Invader6
12-11-2011 10:40 PM
Ohioflathead
03-11-2008 07:07 AM
223ci, 3speed, 5760, 60, bellhousing, column, conversion, f100, floor, ford, interchange, rearend, shift, steering, straight
