cleaning out used intercooler - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-13-2009, 07:46 AM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
I bought a used 7.3 intercooler and it looks like there is some dirt in it, what is a good way to clean it out? Thanks.
Old 07-13-2009, 08:24 AM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule has a good reputation on FTE.BlueMule has a good reputation on FTE.
Dawn dishwashing soap or simple green, either one will remove the oily residue.
Old 07-13-2009, 08:27 AM
wildstang's Avatar
VT Chapter Ldr
So dump some dish soap and then flush with a garden hose? Is that enough flow to flush it well? Maybe block off one end to let it fill up then open it to let it rush out.
Old 07-13-2009, 08:38 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Soak it in a bucket of simple green or super clean.
super clean you can mix with water and still make a good solution
make sure you buy the grease type super clean, there are others that wont work.
If you use dish soap, use hot water and a bucket, and soak it.
agitate any of these every 5 or 10 mins.
Old 07-13-2009, 09:48 AM
wildstang's Avatar
VT Chapter Ldr
I don't think I have anything that big to I could submerg the intercooler in. I may have to rig something up plastic. Thank you the tip.
Old 07-13-2009, 10:05 AM
goatz goatz is offline
goatz is starting off with a positive reputation.
use a garbage can
Old 07-13-2009, 10:11 AM
wildstang's Avatar
VT Chapter Ldr
Intercoolers are pretty wide, I don't think it would fit in a 55 gallon drum. I wonder if a radiator shop would steam clean it. That should flush out the crap shouldn't it?
Old 07-13-2009, 11:42 AM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
Get a plastic child's swimming pool, fill with water and simple green, when done with the intercooler then the whole family including the dog can jump in and take a bath.
Rog
Old 07-13-2009, 12:09 PM
wildstang's Avatar
VT Chapter Ldr
I already have my 4x18' pool up, but that might cost too much for the amount of simple green I would need.
Old 07-13-2009, 10:50 PM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
RubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to all
I was thinking the same question. I was just gonna fill it with carb cleaner and shake it around for a while. Do that probably twice, then air dry....no pun intended.
Old 07-14-2009, 07:15 AM
wildstang's Avatar
VT Chapter Ldr
I think I am going to call a radiator shop today and see if they can flush it. If they can they should be able to get it cleaner then I could. Rather no take a chance of haveing dirt, or whatever else may be in there, going into the engine.
Old 07-21-2009, 10:31 AM
wildstang's Avatar
VT Chapter Ldr
I had the local radiator shop flush it, a little pricy at $40 I think, but maybe a small price to pay to be sure no dirt gets circulated through the cylinders.
Intercooler Removal Traildust 1999 - 2003 7.3L Power Stroke Diesel 9 11-15-2016 09:23 AM
To clean or not to clean intercooler Yahiko 6.0L Power Stroke Diesel 1 07-12-2012 05:17 AM
Intercooler mounting help Wayne64SS 1973 - 1979 F-100 & Larger F-Series Trucks 14 04-03-2012 01:44 PM
Cleaning intercooler 6litrefan 6.0L Power Stroke Diesel 5 09-28-2009 05:29 PM
Intercooler removal Ford79 1999 - 2003 7.3L Power Stroke Diesel 6 04-28-2007 09:22 AM
Tags
1996, 1997, 1998, 73, clean, cleaning, cooler, diesel, f250, ford, inter, intercooler, intercoolers, mod, powerstroke, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
