01-14-2001, 07:55 PM
E4OD vibration 93 F150
Got the same problem with a 95 4X4 150, it seam that the clunk come from the rear end. I found as the fiber pad between the leaf spring wear down, this cause an extra play and the housing assembly till forward on coasting and rearward on accelaration.
The vibration seam to come from the torque convertor when it shift from 3 to 4, it act like a cluch system with a worn pilot b
bushing. There is a couple TSB about that
no:BC03109660601 & BC03109660501.
hope this help
good luck Wrench
>Searched the forums but can't find
>anything similar. 93 F150 4x4
>w/ E4OD tranny. A bit
>of a clunk when pulling
>out from a stop (only),
>and a serious vibration when
>the transmission lugs. The vibe
>is most obvious at highway
>speeds, when the engine begins
>to lug a bit but
>well before a necessary shift,
>and *briefly* goes away if
>I downshift. I never have
>the vibration unless there's a
>load on the engine or
>tranny. Checked U-joints and tranny
>fluid - both seem fine.
>Any ideas?
