Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 08-10-2009, 01:54 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Quote:
Originally Posted by Bovaloe View Post
The F150 its going in has a five speed and the Bronco has an auto with a push button for OD..
So you need a 28oz 164 tooth flywheel for the 5.8, don't use the one off your 5.0 it's 50oz.
What about the computer side of it? Am I doing more than taking one out and plugging the other in?
Not much more, you can use the 5.8 computer but there is a neutral or gear shift indicator that has to be tied to ground or 12v.. can't remember what pin it is right now.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #17 (permalink)
Old 10-27-2009, 08:03 PM
Bovaloe Bovaloe is offline
1991 Ford F-150
Bovaloe is starting off with a positive reputation.
Ok, so my pickup is finally starting to come back together. Been some money issues holding me back but now the engine is about to go back in.
I ended up buying a 408w. I also have got the computer, MAF, pretty much the whole engine wiring harness out of a '95 F150, 5.0, Auto, in the local junkyard (I guess C4C was good for something at least) I have the 2 harnesses close to be made into one for my swap. Ive found a couple wiring diagrams and such so the wiring shouldn't be a prob, but I had a few questions.
First off, how do I remove the pins from the connectors?
What do I need to do about the difference in transmissions?
Is my cruise control gonna work after the swap or do I need something else from the parts pickup? The 95 had a different throttle cable setup
  #18 (permalink)
Old 10-27-2009, 09:34 PM
Conanski's Avatar
1990 Ford F-150
See here for the computer connector.. Ford Fuel Injection EEC Connector
As for the trans difference, you need to find out what trans the donor truck had and then rig up the shift sensor circuit that would normally go to the trans to make the computer think it's always in drive.
__________________
Paul O
  #19 (permalink)
Old 10-29-2009, 07:09 PM
1991 Ford F-150
It has the 4R70W.
On FFI it has all the pins listed and pin 30 has the Manual Lever Position Sensor but how do I make the comp think its in drive?
Also what are the pros/cons of the 2 oxygen sensors, is there any reason to have the 2 or can I just put in 1? Im gonna be putting in LT headers and running true duals, probably no crossover pipe because Im gonna have it dump right under the bed, close to the front.
  #20 (permalink)
Old 10-30-2009, 11:33 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
yes run 2 o2 sensors, this is how the ecu will monitor either bank. also with duals you must run a crossover otherwise it will run and sound like *****
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #21 (permalink)
Old 10-30-2009, 04:55 PM
Conanski's Avatar
1990 Ford F-150
A single O2 jumpered to both computer inputs will work just as well as two individual sensors from an overall standpoint. Dual sensors allows the computer to alter fuel trims individually on each bank of the engine but there really should not be much difference if all the injectors are performing the same.
__________________
Paul O
  #22 (permalink)
Old 10-30-2009, 06:08 PM
1991 Ford F-150
It has the 4R70W.
  #23 (permalink)
Old 11-05-2009, 12:50 PM
1991 Ford F-150
So Ive got all the wiring taken care of except the transmission issue.
Is it as easy as just getting the MLPS off of the 95 F150 and wiring that in and setting it in drive or is there a better way to do it?
__________________
1991 F150 XLT Lariat,4X4, 5-speed, 408w and MAF conversion in the works
1957 Ford Courier Sedan Delivery, 390 FE, Toploader 4-speed, 4.11s, Nitrous
1980 Mustang, built 2.3, 5-speed, budget built street machine -- Work in Progress
1993 Honda XR650L, 13\48 gearing, Dunlop D606s
  #24 (permalink)
Old 11-05-2009, 07:17 PM
Conanski's Avatar
1990 Ford F-150
Yes the MLPS is probably the best way to do it.
__________________
Paul O
  #25 (permalink)
Old 11-08-2009, 09:32 PM
1991 Ford F-150
Alright, engine in, wiring complete, fires but barely runs. Checked the distributor twice its in there in the correct spot. The running seems to be a timing issue but I cant get it running long enough to get the timing set correctly at 10 BTDC.
Anyone have any hints to get it done?
Id really like to get it running well enough to break it in.
__________________
Tags
1991 , engines , f150 , ford , harness , transmission , trucks , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
