Loose Steering and Column - Ford Truck Enthusiasts Forums
Old 07-12-2009, 09:22 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Just nocited today that my 1990 F250 has about a 2 inch play in the steering wheel. What can cause that? Front end or Steering joints?? Seems to have happen out of no where, was fine few days ago. And since i'm talking about steering, my steering column has been loose for a while now, what can that be?
Thanks!
Old 07-13-2009, 02:50 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
There are a ton of joints in these things, here's how the go from the steering box up:
1. rag joint - there is a rubber coupler there, oil eats this with time.
2. slip joint - this is where the two halves of the intermediate steering shaft meet, lower half fits inside the upper and there are two flat springs between them that are supposed to keep things tight, those springs wear with use and sometimes even fall out.
3. external U-joint - this is where the upper half of the intermediate shaft connects to the steering column shaft, even tho the joint is pretty large it still wears with use.
4. internal U-joint - this is for the tilt column, it's inside the column a few inches below the steering wheel.
Try to identify where the play is coming from, then we can suggest repair solutions. Don't forget the steering box itself can have lots of play in it, and this is actually very typical for trucks with high miles on them.
Old 07-13-2009, 11:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
First thing, would this happen to be a tilt wheel?
They have more places to pick up play.
Old 07-14-2009, 12:40 AM
No tilt steering. Plain and simple Column lol.
Old 07-14-2009, 04:17 AM
Even with a straight column you still have joints #1-3, they are all in the engine bay so they should be fairly easy to check for play...
Old 07-14-2009, 06:07 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
my vote is slip joint.
Old 07-14-2009, 06:18 PM
Loose column sounds like the bolts under the dash are loose or the bearings inside are shot.
Does the whole column housing move?
Old 07-14-2009, 06:46 PM
Yes the whole thing moves up and down, and a bit side to side.
Old 07-14-2009, 06:47 PM
i ain't rite
ahhh. ok. then i am with dave on this one. it sounds like the upper column bearings have fell apart.
Loose Steering Wheel PinkyRingz 1999 to 2016 Super Duty 2 09-13-2015 07:25 PM
power steering conversion HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 10 07-05-2015 03:10 PM
steering column 17fordguy 1987 - 1996 F150 & Larger F-Series Trucks 9 04-07-2015 02:23 PM
Steering Column Bearing Replacement Mercmeister 1961 - 1966 F-100 & Larger F-Series Trucks 15 01-29-2015 02:35 PM
Steering Column Compatability/Exchange johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-02-2014 11:48 AM
Tags
column, forum, loose, powerstroke, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
