HELP Fuel Injection Control Module FICM is fried! - Ford Truck Enthusiasts Forums
Old 07-12-2009, 10:23 AM
fixxxer-upper's Avatar
fixxxer-upper fixxxer-upper is offline
FTE Fan
fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.
My FICM has died and I need to replace it ASAP! I really don't want to go to the dealer for this one. Anybody out there selling one or know where I can get one at a reasonable price used, reman, or new?
part # 4C3Z-12B599-ABRM or -AARM
Thanks.
Old 07-12-2009, 11:01 AM
98SurplusExpy 98SurplusExpy is offline
98SurplusExpy is gaining momentum as a positive member of FTE.
Adding a question to this ...
If you get another FICM from a salvage yard off the same year model truck ... is it plug 'n play??
Old 07-12-2009, 11:17 AM
FTE Fan
From what I have read, a used unit would need to be married to my truck.
A new or reman unit will need to be flashed.
Like I said, I will take what I can get to get the truck running this week.
Old 07-12-2009, 12:48 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
If it is from a similar flash it will work. I have an extra one from an '04 that I plan to have tuned by Innovative. To test it out I installed it in my '03 and it ran exactly the same, mileage and everything.
Old 07-12-2009, 03:27 PM
gtdan01 gtdan01 is offline
gtdan01 is starting off with a positive reputation.
I got one if you want and sent you a pm. I was going to get it programmed but am selling my truck so it can go to help someone out.
Old 07-12-2009, 04:22 PM
FTE Fan
gtdan, I sent some info on a PM to you.
Old 07-12-2009, 06:16 PM
FTE Fan
Thanks go to gtdan01 for all the help. I knew I could find what I was looking for in the FTE forums.
Old 07-12-2009, 06:33 PM
UGA33's Avatar
UGA33 UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
I could of got ahold of one for ya. If it doesn't work out, shoot me a PM
Old 07-12-2009, 06:34 PM
UGA33's Avatar
And I see you are in Ga, what part?
Old 07-15-2009, 06:28 PM
FTE Fan
I put another FICM in the truck and it seems to run OK. Should I reflash the unit to marry with the PCM?
Old 07-15-2009, 06:38 PM
If its from a similar flash you should be okay. I think it'll throw codes if there is any incompatibility.
Old 07-16-2009, 11:06 AM
UGA33's Avatar
Glad you got her in.
Old 07-16-2009, 12:38 PM
FTE Fan
Thanks to fellow FTE members for all the help!
Old 07-16-2009, 12:43 PM
Quote:
Yea I believe if it doesn't throw codes it should be okay and will run fine.
Old 07-29-2009, 10:17 AM
lar04 lar04 is offline
lar04 is starting off with a positive reputation.
I'm having similiar difficulties. I need to find a FICM for my ford f350 that is not going to put a hole in my pocket. The cheapest I have come across is 700.00. Do you have any ideas where I can get one quickly. I have to rely on my truck for business and without my truck I make no money. No money...no truck.
I have 2004 f350 6.0L superduty.
Thanks.
Swamps Diesel FICM with a SCT tune? wannabe7.3 6.0L Power Stroke Diesel 9 06-02-2014 11:34 AM
FICM Tuning tiredlr 6.0L Power Stroke Diesel 18 01-04-2013 03:10 PM
FICM Flash mhatlen 6.0L Power Stroke Diesel 3 04-29-2012 01:32 AM
Will FICM need to be Programmed? m350 6.0L Power Stroke Diesel 14 10-08-2011 10:11 PM
FICM Flash or not after repair??? 1954oldred 6.0L Power Stroke Diesel 3 01-04-2010 09:44 PM
Tags
04, 2004, 60, control, diesel, electronic, f250, f350, ficm, ford, fuel, injection, location, locator, module, part
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
