Popping Noise in front end or axle
Hello again, thanx all, for replies on my other post. I have a bigger problem now, When i turn a sharp curve or turn my wheel as far as it can go to turn arround or make a turn-in, A popping and clunging noise appears to be coming from my front end. I have to be moving tho... But the speed does not matter, it still is a dull, lowsound, popping noise and i can sort of feel it in the cab and through my wheel. My truck is a 4x4, 102,000 miles 6.0 diesel. Not FX4. What could it be??? BTW when i first bought the truck, I test drove it and found that it pulled real hard to the right (passenger) side. It would run completely off the road in less than 80ft. I told them to fix it or align it, whatever it needed, then rotate my tires, they did.. Now... few thousand miles later .... The noise!
thanks all for upcoming hep ... Would be appreciated
I had a local mechanic check mine out for the same kinda sound. It would only do it in one direction on mine. He got under there and found a spot on the "bump-stop" for the steering that was shiny, meaning it was hitting when I turned fully. I dont turn all the way much at all anymore and its never been heard since.
jeepfix
1997-2006 Expedition & Navigator
08-22-2015 09:18 AM
95f150
03-10-2004 07:01 PM
