Battery discharge! - Ford Truck Enthusiasts Forums
Battery discharge!
Old 07-11-2009, 12:14 PM
recyclemor recyclemor is offline
recyclemor is starting off with a positive reputation.
Battery discharge!
Battery discharges overnight. Have disconnected alt and have a draw of 8.5 volts off neg post. Found if I disconnect one of the yellow wires off the start solenoid positive side have no draw. Looking for circuit diagram for wiring.
Old 07-11-2009, 12:41 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Connect your meter again and start pulling fuses, that may help to isolate the fault.
Can`t help on the wiring diagram but it would help those that could if you included year/model/engine of the truck.
Old 07-11-2009, 12:45 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
How old is the battery? Try completely unhooking the battery, giving it a full charge, and then see what it's reading. Anything less than 12 volts and it's dead.
Old 07-11-2009, 01:04 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
yup I'm with this post 100%-that way ya can try to isolate where the drain is coming from-just pull one fuse at a time and check to see which circuit is draining the battery
Old 07-11-2009, 01:27 PM
1990 f-150 4.9 L. New battery. Pulled all fuses no change. Meter hooked to neg side battery post to unhooked neg. cable. Shows 8.5 volt draw.
Old 07-11-2009, 01:45 PM
rainbowATF rainbowATF is offline
rainbowATF is starting off with a positive reputation.
Check your battery cables. I replaced my ground and the clamp on my positive. The positive wire looked new. I found that the positive at the starter had the insulation deteriorated from heat (?) back abount 3 inches. The bare wire was green. Apparently moisture created ground path to drain battery. I replaced the cable and battery holds charge and starter cranks like new.
Old 07-11-2009, 02:19 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Quote:
This means nothing.
You need to use an ammeter between the negative post and cable to measure for a drain on the battery. You shouldn't have more than a couple hundred MILLIAMPS of draw. You'll need to pull the bulb for your underhood light, or have someone hold in the switch, everything needs to be off.
Also,
1. What is the voltage on the battery after charging it overnight?
2. What is the voltage on the battery with the vehicle running?
3. Pop off the vent caps on the battery (vehicle not running). There should be six holes with acid showing. Working from one side to the other, stick your voltmeter probes into adjacent holes and measure the voltages (i.e., 1-2, 2-3, 3-4, 4-5, 5-6). They should all measure about 2.1V or more.
Jason
Old 07-11-2009, 09:23 PM
deeznuts822's Avatar
deeznuts822 deeznuts822 is offline
deeznuts822 is starting off with a positive reputation.
Check for stuck relays both fuel pump and ecm. does the fuel pump prime when u hook up the terminals with the key off?
Old 08-23-2009, 07:11 PM
Found bad ecm relay. Thanks deeznuts822 and others for the input.
Old 08-23-2009, 09:09 PM
glad u figured it out
high voltage ckleine 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-30-2014 05:24 AM
2001 F250 (Anyone have wiring diagrams or know what fuse #22 Feeds) SD Rick 1999 to 2016 Super Duty 5 09-01-2013 03:55 PM
F250 V10 2006 Battery Discharge psdendurance 1999 to 2016 Super Duty 21 11-15-2012 04:44 PM
Intermittent battery discharge dalej49 1999 to 2016 Super Duty 6 09-29-2010 08:47 AM
Parasitic Battery Drain - E series 2003 Econoline gearloose1 1999 to 2016 Super Duty 7 11-19-2007 09:07 PM
Tags
1994, 1996, battery, discharge, discharging, disconnected, draw, e250, f150, find, ford, forum, negative, ranger, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
