Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-10-2009, 03:06 PM
Bopper's Avatar
Bopper Bopper is offline
Garage is empty, add now
Bopper is starting off with a positive reputation.
1st engine oil change, torque & washer?
I know the oil filter will be tight as heck to get off. I also have a 2008 mustang w/ the 4.6, so I have experience with these filters.
The Mustang has no oil drain plug gasket/crush washer. In doing a search for the torque settings for the drain plug I came across a drain plug gasket from Rockauto.comm. Does my Expy have a oil drain plug gasket/crush washer, or is it set up the same as the Mustangs plug?
Last, whats the torque for the drain plug?
Thanks
__________________
2008 Expedition EL Limited 4x4, Black on Black, Moonroof, Rearview Mirror Camera, Power Liftgate, Luggage Rack, Purchase Date 1/09
Pioneer AVIC-900BT w/ Rear 10.5" DVD/Monitor
  #2 (permalink)
Old 07-12-2009, 03:55 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
My last 3 Fords have all had a rubber gasket that was part of the drain plug. None of them called for a gasket outside of that. As far as torque, I've always been a "snug it up and a pinch more" type guy with drain plugs. I can't even tell you how many hundreds or thousands I have done and I've never torqued one. No comebacks either.
  #3 (permalink)
Old 07-12-2009, 05:03 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Take it to the dealer. I know that my first oil change was included in my purchase.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  #4 (permalink)
Old 07-12-2009, 08:00 PM
Bopper's Avatar
Well, I found the torque setting for the Mustang 4.0, 4.6, 5.4 drain plugs and they are all 19 lbs/ft. So I would bet that is a good place to start for the Expy.
__________________
Tags
2002, 2007, 73, capacity, crush, drain, expedition, f150, f350, filter, ford, oil, plug, settings, torque, v10, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
