2003 ford f250 6.0L turbo diesel problems help - Ford Truck Enthusiasts Forums
Old 07-10-2009, 02:16 PM
caleb1563 caleb1563 is offline
caleb1563 is starting off with a positive reputation.
i have a 03 f250 and when its cold it barley starts and its not driveable until it is warm it was never like this before and on top of that the turbo is not working at all
any ideas at all thanks
Old 07-11-2009, 12:05 AM
GRAY MULE GRAY MULE is offline
GRAY MULE is starting off with a positive reputation.
i have the same truck as you,and had the exact same problem with mine,so i took it to my dealer and first of all i needed my computer reflashed and updated with a cold start update,and secondly i had 2 injectors down also. i let the dealership fix it and sadly it cost me 1200 bucks parts and labor, but happily it runs like a brand new one now.
Old 07-12-2009, 01:18 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Welcome to FTE caleb1563 I moved you from General Diesel to year specific for your engine. Can you give us information on the truck, original owner ect?
Old 10-18-2011, 09:54 PM
bigdad bigdad is offline
bigdad is starting off with a positive reputation.
i have an 2003 f350 with a 6.0 and it wont start. i replaced the high pressure oil pump.still no start,,please helpme
Old 10-18-2011, 10:04 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Look in the Tech Folder - there is a no-start troubleshooting thread.
We also need specifics:
Any mods?
codes?
Any recent issues w/ alternator or batteries?
How long did you crank after the HPOP replacement?
What oil and oil filters are you using?
Old 10-18-2011, 10:31 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Gauges would also be a big help here to check things out like your FICM
Alot of us on here run a Scan Gauge or Edge Insight I beleive
I use the SG great unit for 160.00 check it out
www.scangauge.com
But some things can be checked with a DVM=digital volt meter if in a pinch
Here is the trouble shoot checklist Bismic suggesteed
http://www.ford-trucks.com/forums/87...condition.html
Old 06-13-2013, 07:06 PM
eode6s eode6s is offline
eode6s is starting off with a positive reputation.
2005 6.0, no power!! No acceleration, cannot even get out of her own way. Had her in reverse, had to look to see if she was in neutral; as there was no movement what-so-ever. Visit to Dealer; all 8 fuel injectors, 8 glow plugs, and Y pipe changed. $4300 and dealer says there is nothing wrong with her. New EGR, air, oil and fuel filters. Running Royal Purple 15w40 syn. Only mods are volant cold air intake and after market exhaust. I am at a loss.
Old 06-13-2013, 08:40 PM
bismic's Avatar
see post #5
Old 06-13-2013, 10:07 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
really reopening a 5yr thread?
listen to mark, post your results in a new thread
turbo trouble arnhed 1987 - 1996 F150 & Larger F-Series Trucks 2 04-01-2016 06:55 PM
Has anyone turbo-ed a 390 FE?? mustangsvo85 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 25 03-03-2016 08:08 PM
BROKEN TURBO SHAFT ??? 03f2506.0 6.0L Power Stroke Diesel 4 09-11-2015 06:18 PM
Turbo? 20007.3f250 1997 - 2003 F150 2 07-03-2015 01:38 AM
460 turbo options? Dustin460 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 09-11-2009 02:29 PM
Tags
2003, 2005, 2006, 250, 60, 60l, diesel, f250, f350, ford, forums, problems, reviews, starting, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
