6V to 12V, older conversion
Our 50 Ford was converted many years ago, has a 12V generator in place of the 6V. However, other then the outside lighting, nothing else has been done to it.
Amps: reads fine, not dependent on voltage
Fuel Guage: I've determined it works kinda, when it's full it's "F" and when it gets near empty it drops to "E", there is no in-between.
Temp: Reads fine
Oil Pressure: running it reads 30, but there is also an aftermarket gauge.
Of course the dash lights do not work, the heater blower works, though...
Temp: Reads fine
Have you looked under the dash to see if the gauges were properly converted, with an instrument regulator or Runtz regulators, etc.?
Mine is properly converted, and the oil pressure gauge reads 30 when it is actually (as measured with a good mechanical gauge) 50 psi. They can be adjusted to a point.
Many instances of the gauges working fine on 12v, but usually not for long.
1948-55 Ford F-100 Voltage Reducer, Elctrnc Single Gauge, Runtz
When installing your runtz, pay attention to their position relative to everything else under the dash. In particular, it's possible for the runtz on the oil pressure gauge to short against the vacuum motor. If your motor happens to have a film of oil on it from a sloppy attempt at oiling it, it's possible to create a pants soiling amount of smoke.
I'll let you guess how I know this.
DGRisley
09-28-2016 11:12 AM
winkohl
01-18-2008 09:26 AM
bryanknie
06-26-2002 12:33 AM
DanB98TJ
04-17-2002 10:15 PM
