Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 07-10-2009, 09:33 AM
BEAST428 BEAST428 is offline
2003 Ford Excursion
My Garage
BEAST428 is gaining momentum as a positive member of FTE.
Which Gears??
I am in the process of getting the "Beast" (see my garage for pic) back on the road and I have a question. It is a 1974 F250 chassis 4x4, with a 428CJ, a 4 speed good old granny trans and I think a Dana 24 divorced transfer case. It has 40" Gumbo mudders on it now. The rear end is a Dana 70 out of a 75 F350 dually with 4.56 gears. I am planning on putting a coil sprung front end out of an 05 350 Super duty in it. This axle has 3.55 gears. Future plans include dual transfer cases and possibly larger tires. My question is which gearset should I change, the front or the rear? I know the wheel bolt patterns will be different and that I will have my work cut out for me adapting the front axle to the frame and steering, but the rig has an old Dana 44 closed knuckle front in it now and I have the Super duty front end laying in the back of my shop collecting dust.
I am looking for max power, not gas mileage. I would like to get this done before winter hits. Thanks. If anyone in my area wants to help, let me know.
  #2 (permalink)
Old 07-10-2009, 09:46 PM
PatsPOS PatsPOS is offline
Garage is empty, add now
PatsPOS is starting off with a positive reputation.
Jeez...I'd think that with two transfer cases, the 3.55 gear should be OK. Hell, I'd think that if there was a taller gear available, you'd be safe with that!
Of course, if you go with the 4.56 gears and dual transfer cases, you could go enter "slow truck" contests.
I'm no expert, but with that kind of torque multiplication, a fairly high gear shouldn't be an issue. And I still haven't even started painting my truck yet, but I might be able to spare a few hours here and there if you'd like some assistance...all you gotta do is ask!
Later...
Pat
__________________
'89 F-150 F14 4.9L (18.37 @ 73 MPH)
'91 Crown Vic P74 5.0L (18.09 @ 75 MPH)
'75 Gran Torino 7.5+L (14.04 @ 97 MPH)
'00 Excursion LTD 6.8L (ET & MPH TBD)
  #3 (permalink)
Old 07-12-2009, 08:38 PM
cbradford's Avatar
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
With the 40" tire I would go with the 4:56's for sure.
__________________
Chris
05 Excursion Limited V10, 4:30(C3) Limited Slip
01 Expy EB, 5.4, 3:55 Limited Slip, 2006 27' Outback T.T. 7000lbs-loaded
  #4 (permalink)
Old 07-13-2009, 10:29 PM
jpb222 jpb222 is offline
jpb222 is starting off with a positive reputation.
Stay with the 4.56's for sure with 40 inch tires.
__________________
two restored 1979's a 350 4x4 and a low mile 150 2wd
three 66-77 EB's, one restoration, and 2 rock buggies
three 48-52 f-1 pickups, one sleeper, one 4x4 DD and one restoration project
  #5 (permalink)
Old 07-22-2009, 02:43 PM
BroncoBitch's Avatar
BroncoBitch BroncoBitch is offline
BroncoBitch is starting off with a positive reputation.
might be able to go with 4.88's thats what i run in the one bronco withteh front 60 rear 70 and 42's
  #6 (permalink)
Old 08-03-2009, 08:04 PM
2003 Ford Excursion
My Garage
I am going to take the housing and one axle to my local spring shop to get straightened in a week or so. I decided to use 4.56 gears. I will need one radius arm from a 05 or newer F350. Two 73-79 F150 upper coil spring perches and a track bar of some kind to mount the axle. I also have a steering box out of a late 80s E350 ambulance that I think I can use to set up power steering. Camping season will be over soon so I figure to get into it the first of September.
  #7 (permalink)
Old 08-03-2009, 10:25 PM
soondg's Avatar
soondg soondg is offline
Peek a boo poster
soondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud of
the 4:56's sound good to me Beast. I have them in my 83, with the old 460, C3 and 38's there was no problem turning them or losing torque. Just uses a lot of gas. I have since put a 400 in it but haven't had it on the road yet. Yes I like torque.
__________________
Joe
STUFF IS COOL-TORQUE PULLS MORE STUFF- TORQUE IS COOL
Pennsylvania Chapter, Home of the Mid Atlantic Meet JOIN US HERE!
Tags
456, f350, gears
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
