Which Tranny is code E?
on
1 Post
I have money down on a 1990 Class C motorhome with Ford (Yeah!) 460 V8. It has an automatic (Boo! But have to satisfy the wife) overdrive tranny. The selector goes P,R, N, OD, 2, 1 and then there is a pushbutton on the dash where you can cut out the OD. The door sticker says Trans is "E." VIN is 1FDKE30G4LHA91252. Is this the E4OD or the AOD?
on
1 Post
Thanks, In talking to a company that does service and repair on motorhomes I learned it likely is the E4OD and that there were three versions of it. According to the pan configuration, it likely is the heavy duty truck version. Anyway, when I test drove this beast, I sure was glad to have the OD. Running with the cut out made it wind quite a bit. Has 4.11 rear end to move its 9000 lbs.
turboguy
03-13-2005 04:36 PM
