Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-10-2009, 09:00 AM
manimal_fla manimal_fla is offline
manimal_fla is starting off with a positive reputation.
4.0 5 speed 3000 rpm @ idle....HELP
96 Explorer XLT,never had a problem.Now it's been to the mechanic who is very reputable here in town.He said he swapped all sensors and still it idles between 2500-3000 rpms.I unhooked the IAC and the idle is now too low and wants to stall at idle most of the time.Problem is about a 2 weeks old now and I'm driving it with the IAC unplugged.Can't find a vacuum leak and going crazy because if it don't have a carb I am lost.The mechanic says replacing the computer is the next step.Anything I can try before replacing it would sure save my pocket,especially since he didnt seem sure this was the sure fix.Any help is greatly appreciated.Thanks
  #2 (permalink)
Old 07-10-2009, 12:34 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Try a new mechanic. You unplugged the IAC and it idles low. Hhhmmm, what could that point to? Replacing sensors and this and that works sometimes, and can be cheap if you get lucky. But I'd throw a flag on the computer switch. This sounds like a mechanical problem with an electronically controlled part at the throttle area.
Get out the Yellow pages. Ask 'em if they've worked on this, and how many. If you get hims and haws, or 'uhh, let me check', just call the next one. I'd even consider a dealer. Find guys who used to work for Ford with their own shop.
Good luck.
  #3 (permalink)
Old 07-15-2009, 12:08 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
He swapped all the sensors and it still doesn't work? Sounds like he's not really a mechanic, just a parts changer. Some diagnosis needs to be done on it. Have the codes been pulled? Always a good place to start. Also, in replacing sensors did he replace the IAC? (It's not a sensor, it's an actuator.)
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Tags
3000 , 3000rpm , 40 , cam , ford , idles , overhead , rpm , rpms , single , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
