Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-10-2009, 07:32 AM
95 F150 Dude 95 F150 Dude is offline
95 F150 Dude is starting off with a positive reputation.
Interior Trim
Guys,
Just bought a 93L as a rolling chassis and I am in need of a couple of interior trim pieces. What model F150/Bronco came with the same charcoal colored interior?
Also, in need of the plastic rear tube bumber step.
Scott
  #2 (permalink)
Old 07-10-2009, 08:10 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE. Virto has a good reputation on FTE.
93 Lightning? I thought the dash and trim was all a unique color to the lightning, with gray, red, tan and blue being available in the standard trucks.
Hope down to the 87-96 section, several people have done lightning conversions and know much more about them than I do.
__________________
Quote:
Originally Posted by Silver Streak View Post
You're having problems because some butthole put the wrong one on your truck.
1990 Ford F-150 XLT Lariat Supercab - 5.0/E4OD - Dead and gone.
1993 Ford F-150 XLT Supercab - 5.0/AOD - 3.55
  #3 (permalink)
Old 07-10-2009, 08:23 PM
Virto,
I am missing some pieces and thought someone here would know of another model that would interchange with the one year only 93L interior.
  #4 (permalink)
Old 07-11-2009, 04:55 AM
TexasGuy001's Avatar
TexasGuy001 TexasGuy001 is offline
TexasGuy001 is gaining momentum as a positive member of FTE.
If its the darker gray then 92-93 should be the same gray regardless of F150 F250 F350 Bronco etc. From 94-96 it was a lighter gray.
__________________
1995 F-150 XLT 2WD 5.0 AODE (4R70W) 3.55 LS
1965 Mustang 302 T5
PICTURES AND INFO IN GALLERY
  #5 (permalink)
Old 07-14-2009, 09:32 PM
paperhanger paperhanger is offline
paperhanger is starting off with a positive reputation.
Quote:
Originally Posted by polljimmy View Post
Installing trim is one of the most rewarding home improvement projects you can do. No matter what style you choose, you’ll take pride in the finished product . . . as long as you get all those joints tight.
  #6 (permalink)
Old 07-19-2009, 09:30 PM
my94lightning my94lightning is offline
my94lightning is starting off with a positive reputation.
Quote:
correct, 92-93 = dark charcoal grey
I belive 94-96 = medium opal gray
what parts specifically are you looking for? We might have better advice on where to find em.
  #7 (permalink)
Old 07-19-2009, 09:35 PM
[quote=Virto;7703966]93 Lightning? I thought the dash and trim was all a unique color to the lightning, with gray, red, tan and blue being available in the standard trucks.
only the seats, perferated leather steering wheel, the orange pointers on cluster w red line on tach in red paint. and possible 93 door panels cause I havent seen the felt insert that 93 L door panels had on anything else yet.
other than that its all normal upper level xlt stuff
  #8 (permalink)
Old 07-19-2009, 09:42 PM
my94lightning,
I am in need of a glove box door, drivers door panel (my felt trim is in really good shape), and molding over the drivers side door window.
Scott
  #9 (permalink)
Old 07-19-2009, 10:05 PM
well, since what you describe are (cheaper parts ish)except door panel, I would have a buddy at a dealer run a locate, and see if anywhere shows them available.
1 glove box
2 drivers A pillar trim
3 drivers door panel
#1 should be easy find, and not to expensive.
#2 Are you talking about the trim that goes up from the dash and then to the rear of roof, and it holds up the headliner?, if so its called a A pillar trim, if not, is molding atached to cab or door?
#3 door trim panel is expensive if it is available still, you say your felt is good, what is wrong with your door panel? also I believe the felt inserts do not come off the door panel, I think they are plastic welded from behind.
  #10 (permalink)
Old 07-23-2009, 04:39 PM
my94,
Sorry it took so long to respond, I was camping in Tennessee. There is a truck boneyard near me so I will try there and see what I can come up with. If that turns up nothing then I will try some alternative sources.
  #11 (permalink)
Old 07-25-2009, 12:29 AM
y2kfordparts's Avatar
y2kfordparts y2kfordparts is online now
I make my job look easy!
y2kfordparts is a splendid one to behold y2kfordparts is a splendid one to behold y2kfordparts is a splendid one to behold y2kfordparts is a splendid one to behold y2kfordparts is a splendid one to behold y2kfordparts is a splendid one to behold
i'll help you, visit my site send me what you are looking for and give me a vin so I get it right. I'll see if there are any parts avail or at another dealer.
Ed
__________________
Join us at the next Riffraff/Partsguyed II East event details.......
ESP WEB SITE BACK UP AND RUNNING CLICK ON LINK FOR QUOTE Y2K-ESP
WE DELIVER WHAT OTHERS ONLY PROMISE!
Tags
2002 , 93 , 94 , 95 , 96 , codes , color , door , f150 , ford , interior , medium , opal , paint , panel , plastic , trim , window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
