put truck in reverse, it shuts off. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-09-2009, 05:36 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
this happened to me this morning when I got off work, I stopped to back into the driveway, put it in reverse and truck died. This afternoon when I got to work I stopped to back into my parking space and truck died. Its never done this before, I have a little over 50K miles on it. Im thinking TPS taking a crap? anybody wanna chime in?
Old 07-09-2009, 05:52 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
Possibly the low/reverse sprag (one way clutch) ? Any codes? Does it shut off immed. or stumble? Do it everytime? need more info.
Old 07-09-2009, 06:09 PM
no codes, shut off immediately. so fars its done it 2 out of 2 times.
Old 07-09-2009, 06:11 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
i am thinking maybe the tcm.
Old 07-09-2009, 06:14 PM
I have limited knowledge of the torqshift but I do alot of trans work, seen the low/reverse sprag do this on other trans. Maye the ford trans engineer (cant remember his user name) will shed some light soon.
Old 07-09-2009, 06:25 PM
its never done it until today, sometimes when I put it in reverse the rpms drop kinda low and it'll shutter but I never thought anything of it.
Old 07-09-2009, 06:27 PM
senix's Avatar
Quote:
yeah, there might be a communication issue between the tcm/pcm. just my thoughts.
Old 07-09-2009, 07:37 PM
Quote:
If it were a communication prob it would set a U code on the network it is trying to communicate on.
Old 07-09-2009, 07:42 PM
KSCRUDE KSCRUDE is offline
KSCRUDE is starting off with a positive reputation.
Could be the dirt sucking k+n filter. Just a wild guess though.
Old 07-09-2009, 07:46 PM
K&N has been on there since 06. gets cleaned and maintained regularly.
Old 07-09-2009, 08:13 PM
That sounds more like and IAC. Pretty notorious on fords.
Old 07-09-2009, 09:18 PM
yeah thats why I never thought anything of it, its a ford thing. I just dont like the fact that the motor craps out when I use reverse lol.
Old 07-09-2009, 09:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Is the trans fluid low? That can make the torque converter clutch apply when it shouldn't, which will stall the engine.
Old 07-09-2009, 11:16 PM
dstig1 dstig1 is offline
dstig1 is gaining momentum as a positive member of FTE.
No IAC on the drive by wire trucks ('05 + gassers). That's part of what the drive by wire buys you (well, Ford).
Old 07-09-2009, 11:23 PM
jk080's Avatar
jk080 jk080 is offline
Gear Head
jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.jk080 has a very good reputation on FTE.
The filter is known to come loose in the pan and can create a situation that's like it low on fluid like Mark said.
Check the fluid level, if ok then remove the pan and check the filter. Superior makes a clip the keeps the filter from falling out of the pump.
I have seen this happen to the E40D too.
my 87' ranger v6 2.9 dies in reverse. Carl Tritch 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 0 08-27-2016 07:39 AM
2000 F350 sputtering in reverse Happy Beggar 1999 to 2016 Super Duty 0 10-12-2014 03:39 AM
06 v10 Truck Dieing matconger Modular V10 (6.8l) 12 02-15-2013 03:46 PM
?? Reverse Sensors stopped working rfairwea 6.0L Power Stroke Diesel 24 01-01-2011 02:31 PM
F250 Shutting off when putting it on Reverse. KAT_Ayanami Clutch, Transmission, Differential, Axle & Transfer Case 6 05-09-2010 06:48 PM
Tags
06f250, 1999, 4r100, 54, drive, f150, f250, ford, problem, put, reverse, shuts, stall, stalling, stalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
