Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 07-09-2009, 04:23 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Garage is empty, add now
Pkupman82 is gaining momentum as a positive member of FTE.Pkupman82 is gaining momentum as a positive member of FTE.
Cruise control not working...
Hey guys and gals, I am trying to figure out why the cruise control on my 96 F150 isn't working. So far I have checked all the fuses and under hood connections, I replaced the shut off switch on the master cylinder. Any ideas?
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ NP435/ 205
1979 Ford Bronco XLT Ranger/ 460/ C6/ 205
1984 Ford F250 XL 4wd/ 6.9 IDI/ C6/ BW1345
1984 Ford F150 4wd/ 300/ NP435/ 208
1996 Ford F150 XLT 4wd/ 300/ ZF5/ BW1356
  #2 (permalink)
Old 07-09-2009, 04:39 PM
redlightning93's Avatar
redlightning93 redlightning93 is offline
redlightning93 is starting off with a positive reputation.
Does your horn blow?
If not it sounds like a Clock Spring.
__________________
1996 Eddie Bauer Supercab, 5.8, E40D, 3:55 LS, 2WD short bed.
  #3 (permalink)
Old 07-09-2009, 05:01 PM
Pkupman82's Avatar
Yep, the horn works fine. I was wondering if it might be something in the steering column. I can't seem to find a good trouble shooting guide for this system anywhere.
__________________
  #4 (permalink)
Old 07-09-2009, 05:36 PM
Sportruk's Avatar
Sportruk Sportruk is offline
Sportruk is starting off with a positive reputation.
Sometimes the module itself rusts up. It's on the driverside inner fender, with a cable that runs to the throttle body. You can remove the cover, which is the electronics of the module, and check to see if the drive motor is seized. I had to use a pair of pliers to loosen it and put some oil on the bearings.
Click the image to open in full size.
__________________
Shawn.
2008 FX2, 5.4, 3.73 LS, Leer Lid.
1988 F150 408 carbed, Lentech AOD, 3.73 LS, IRS, AirRide, Chop Top, Shaker Hood Scoop and A Few Other Mods.
  #5 (permalink)
Old 07-09-2009, 10:10 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to behold
Make sure all your brake lights work, if one is out the cruise doesn't work
__________________
96 F350 CCLB 460 5pd 4x4 /97 F250 CCSB Dually 7.3 5 spd 4x4
94F150 RCSB Lightning/86 F250 RCLB 6.9 4spd 4x4
80 F350 RCLB 429 C6 4x4/
04 Ranger SCSB
96 Bronco 347 5speed
  #6 (permalink)
Old 07-09-2009, 10:50 PM
mstngmikegt's Avatar
mstngmikegt mstngmikegt is offline
mstngmikegt is starting off with a positive reputation.
Never have figured out what's wrong with the cruise on mine. Tried to troubleshoot last year and gave up. Even replaced the cruise module with what should have been a good (but never tested prior to install) used unit and still nothing. Horn works, no airbag light after start up and brake lights work fine. Really don't believe the clock spring is bad and sure don't want to go through the hassle and cost to just toss a new one in either. Oh, and had the master switch recall done too. Am really curious what you find.
__________________
Rides:
1995 F150 XLT 4X4, reg cab longbox , 150K miles, 5.0L/4R70W, 3:31's, 31X10.5's
(year round driver, winter snow biter)
1987 Mustang GT 5sp, 107K miles, GT40P's, E303, Explorer intake, 3.55's, just fun stuff
(summer toy, winter hermit)
  #7 (permalink)
Old 07-10-2009, 03:50 PM
Pkupman82's Avatar
Thanks for the replies guys I'll have to do some more checking. Any more feedback is appreciated.
__________________
  #8 (permalink)
Old 07-10-2009, 04:55 PM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
Here is some hints on Fords Speed Control, do not know much about the GM cruise control.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #9 (permalink)
Old 05-02-2010, 01:38 AM
devyn88 devyn88 is offline
devyn88 is starting off with a positive reputation.
1984 f-150 2wd cruise not working horn is
i have a 1984 f-150 and i recently replaced my crise control panel/horn bar and found out my horn and cruise didnt work i traced the horn problem to a relay under my dash but still havnt figured out the cruise though.any sugestions?ps fuses are all good.is there a seperate relay?if so where is it hiding?
  #10 (permalink)
Old 05-02-2010, 06:15 AM
subford's Avatar
Quote:
There is a module under the dash that operates the Speed Control.
I do not remember where it is on a truck but it is near the steering column on a van.
__________________
subford@gmail.com
  #11 (permalink)
Old 05-10-2010, 03:16 PM
steves_F350_460 steves_F350_460 is offline
steves_F350_460 is starting off with a positive reputation.
Can anyone tell me what the cable / connector looks like the the cruise control module? I think I have the cable, coming in the firewall and leads over to where the ECM is mounted, but no box or module for the cruise .......... ALSO, I'm having brake trouble with the pedal going all the way to the floor, and NO fluid loss anywhere, was told it may be the ABS module ........... then I heard that the ABS & cruise control systems share the same modules .......... it gets does get easier ... right ? My truck is a 88' F-350 with the 460 efi and c6 transmission. PS: there is an ABS sensor mounted on the upper part of the rear differential !
  #12 (permalink)
Old 05-10-2010, 07:17 PM
subford's Avatar
Quote:
The cable going from the transmission to the speedometer has a generator half way and the wires from it go to the Speed Control Module.
Maybe the ABS valve but not the module.
No they have different modules.
__________________
subford@gmail.com
  #13 (permalink)
Old 05-10-2010, 08:22 PM
Thanks subford. WHERE IS THE ABS VALVE LOCATED ON MY TRUCK? Plus, I'm not sure my truck even came with factory cruise control, at least the steering wheel presently in the truck doesn't have the function buttons for cruise OR the tilt feature normally found as a combo'd pair of options from FORD, so maybe the thing never had cruise, BUT, there is a 3 prong female electrical plug / wire coming in through the firewall and tucked behind the left side kick panel in the area of the ECM unit ..... I just can't figure out what this thing is ????
  #14 (permalink)
Old 05-11-2010, 09:49 AM
subford's Avatar
Maybe these will help:
__________________
subford@gmail.com
  #15 (permalink)
Old 05-11-2010, 10:15 AM
Yes, helps HUGE !!!! What manual are the diagrams from? Chilton's ? I'll have to pick one up to be sure. I don't see the electrical connector I'm referring to in any of the diagrams. I think the truck must have had trailer brakes at one time and the connector was used to hook up the brake controller inside the cab. None the less. I did find the ABS module under the dash and is connected to the harness. My brakes still fall all the way the floor with not much resistance, until the last 1/2 inch maybe before I get any braking action at all. NO fluid leaking anywhere, so there must be a "brake system" component failure, just need to figure out where it is. Thanks again for the post.
Tags
1995, 2001, 4wd, control, cruise, f150, f250, flareside, ford, forum, horn, ranger, seized, troubleshooting, truck, work, working, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
