6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
wiring fault on trailer message
Old 07-09-2009, 03:53 PM
ctownson's Avatar
ctownson
ctownson is offline
This morning, when I started my 08 f250, I got a "wiring fault" message on the information center. No trailer is connected to the truck. I hit info and then reset to clear the message. Now, every time I start the truck, I am getting this same wiring fault on trailer message in the console.
Any ideas? Thanks!
Old 07-09-2009, 05:19 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
sounds to me like your TBC is bad.
Old 07-09-2009, 05:48 PM
ctownson's Avatar
ctownson
ctownson is offline
I have to take it in for an oil change next week; I'll call and add this to the list before going to the dealer.
Old 07-09-2009, 09:49 PM
LJC's Avatar
LJC
LJC is offline
Any ideas? Thanks!
Got this same issue last year. It's a sensor that is causing this issue. The "sensor" is placed under the hood on the driver's side under the break-fluid bottle. They'll change it and everything will be back to normal.
LJC
Old 07-10-2009, 05:51 AM
ctownson's Avatar
ctownson
ctownson is offline
Thanks - I will update the results after the dealer looks at it next week.
Old 07-11-2009, 10:31 AM
bojes's Avatar
bojes
bojes is offline
Had same problem. Check the plug on the rear bumper for water infiltration. When ford tech removed plugin, and tilted it, water came pouring out. They replaced plug and taped backside to keep out water. Hope this helps.
StanleyZ
6.7L Power Stroke Diesel
01-30-2015 10:56 PM
mnmwhit
12-16-2012 01:56 PM
fairhaven
1999 to 2016 Super Duty
10-06-2012 05:34 PM
pilotshot
17
02-09-2009 02:37 PM
Paige Haddock
05-07-2007 03:15 PM
Quick Reply: wiring fault on trailer message
