Towing a vehical
Towing a vehical
I was going to tow my classic mustang. Called up Uhaul and rent either a full trailer or a tow dolly. Was told my ranger is not enough for either of these? Does that sound right? I see stuff hauled all over the place with trailers and tow dollys and no issues. Is this guy steering me right? Any way around this?
Its not that they wont let you use the dolly with the ranger, its the fact that the mustang is one heavy old car. I needed a car dolly one time to pull my '91 infiniti m30 vert. The tow vehicle was my '91 ranger 2wd 4.0 auto. They said that the car was too heavy of a load. So I told them I also needed it to tow my '92 geo metro. Cant get much lighter than a metro. The uhaul guy gave me the dolly and I was on my way. The ranger pulled it just fine. Braking requires some close attention but all in all it wasnt too bad. Im not saying to lie to uhaul but when you are out of options, rules tend to get bent a little bit.
Well a number of things need to be considered here.
Your engine, tranny, differential gear ratio, tire size, weight to be towed & method of towing, distance & terrain.
Pulling the load is only part of the equation, stopping it should be considered too, as has been said.
Your owners manual will give max tow weight guidelines.
If your going any distance at highway speeds, a larger tow vehicle sure would be a better & safer idea.
the main thing you should to consider. At coasting trailer must press on hitch, but not raise it, else....
uper picture shows the most dangerouse situation. at coasting will rais rear axe and make it skid. My fiend got roll over crash driving down a hill. fortunatky speed was about 35-40 MPH and nobody was injured.
well, read here http://www.dmv.ca.gov/pubs/dl648/dl648pt12.htm
http://www.truckspring.com/about_684.html
http://www.hitchsource.com/hitch_guide.php
I dont know about your roads in the ukraine, but from my experience the roads around here are steller in comparison to what I saw several years ago in italy. So I have decent roads. Also, being in florida there are NO hills. Almost all of this would be on highways, but would be going rather slow.
Dont remember gears, tires are stock, have a very large passive tranny cooler (no fan)
this is what I expect the dolly to look like:
I have had the same problem with U-Haul... I towed an S-10 ZR2 (stripped) with another S-10 ZR2. U-haul refused to rent me a trailer because of the load weight. They use a calculator (on their website) for everything. There is no way to deduct weight if you have stripped anything off of it. Their calculator uses the GVW of the base model truck.
Instead we went around the corner to Taylor Rental & rented a flatbed for $75 no questions asked.
The axle code is on the door sticker & you can look up the tow info in your owners manual, or if you don't have one, it can be down loaded from
https://www.fleet.ford.com/maintenan...ls/default.asp
If you've changed the Rangers tire size, that'll figure in too.
Make sure ALL of your fluids & systems are in good condition, if in doubt, change the fluid/s & maybe consider synthetic crankcase, tranny & power steering fluids & be sure to flush the brake system with some Motorcraft PM-1 Dot-3 brake fluid.
The fact that you have the 3.0L Vulcan in a 4X4 extra cab, means it's lugging around lots of extra weight, so that'll cut down on what you can tow or haul.
The chart I have says that the 99 Ranger Super Cab, with a 3.0L Vulcan engine & 4X4 with auto tranny, has a max trailer weight is 4200 lbs with the 4.10 rear differential & 3700 lbs with the 3.73 differential.
If you have the tow package with heavier rear springs, that would be good, as it'll help with handling.
The tranny cooler is a very good thing, because you'll be working it plenty hard in hot weather & heat kills auto trannies.
I assume you plan to tow the vehicle with two wheels up, so if the drive wheels are down, maybe consider taking the driveshaft off, so the tranny output shaft isn't turning.
More tow thoughts for pondering.
Will be interesting to hear what you do & how it goes.
