H10 Spark Plugs not available. What do you guys use? - Ford Truck Enthusiasts Forums
Old 07-09-2009, 04:23 AM
turnrjr turnrjr is offline
turnrjr is starting off with a positive reputation.
The book says my 223 should use H10 plugs. I can't find them. Searching turns up lots of substitutes. What are you guys using? Does it really matter as long as the bottom end is positioned correctly in the head.The truck is a 54 F100 but the block is newer. Plugs are 14 mm thread. Thanks.
Old 07-09-2009, 06:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
7RA-12405 .. Spark Plug
Originally these were Champion H10's.
When Ford bought Auto-Lite, they became: 7RA-12405-A .. Auto-Lite AL7.
When Ford sold Auto-Lite in 1972, AL7 was replaced by: B7A-12405-A .. Motorcraft BTF6
Considering the 100's of different vehicles that used Champion H10's, I find it impossible to believe that no one has any.
Try a good indie autoparts store. You could also try Green Sales in Cincinnati OH (800-543-4959).
The chain auto parts stores are clueless when it comes to parts that haven't been used since grandma was a girl.
EDIT: Dennis Carpenter (704-786-8139) has Champion H10's @ $3.50 each.
Their part number: 7RA-12405-H10
Old 07-09-2009, 08:13 AM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
early ford v-8, ballston spa NY has h-10 at $2.95 per. not far from western mass. http://www.earlyford.com/ just bought some recently. dick r
Old 07-09-2009, 09:12 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I had trouble with H-10's. Now I'm using Autolite 216's and with very good results. NAPA and some AutoZone's carry them. Any store that sells lawnmower parts should have H-10's.
Old 07-09-2009, 08:11 PM
Bill, Dick and Ross thanks. Ross what kinda problem did you have?
Old 07-09-2009, 09:09 PM
ALBUQ F-1's Avatar
postin' fool
A couple of them just didn't seem to burn clean. No matter which cylinder I put them in, they would get black and start to miss eventually. There was an old one that just flat wouldn't fire (but it had been in the truck for god knows how long).
H.(Hodgepodge)I.D. install Apocalypse Excursion - King of SUVs 12 11-13-2015 01:26 PM
Aftermarket Turbo/Wastegate Solenoid valiant500hp 1999 - 2003 7.3L Power Stroke Diesel 6 06-10-2012 05:38 PM
H&S tuner on 6.7 deedsF350 6.7L Power Stroke Diesel 25 02-20-2012 11:46 PM
Spark Plug Gap Question John - NNY 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-27-2006 07:28 PM
H-4 Headlight Conversion DPW 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-12-2003 08:31 AM
Tags
223, autolite, champion, flathead, ford, h10, h10i, motorcraft, number, part, plug, plugs, spark, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
